It is currently Fri Nov 17, 2017 4:10 pm
Specs needed on a Carver KLW AUDIO K MOS 2200
JT240Z
Post Thu Feb 03, 2005 8:51 pm
Can anyone tell me the output power specs on a Carver KLW AUDIO K MOS 2200 amp? Is it 2 X 200?
Also, if anyone is selling an M series amp (M-240 or M-4120 for example), I may be interested.
bonesgt
Post Tue Dec 20, 2005 7:35 pm
I had two K MOS 2200s at one time...
Now I only have one driven a Pioneer IMPP 12" Sub.
I'll look and see if I still have the owners manual here.
Must say these are great amps!!!
Amp mounted in the back of my 87 Mustang GT
bonesgt
Post Tue Dec 20, 2005 8:00 pm
Better late than never....
2x100w.
300w RMS.
Two 25 Amp Fuses
Two Loud Speaker Outputs (Bridgeable)
Two Hi-Level Inputs
Gold Plated Lo-Level Inputs
Gold Plated Hi-Pass Outputs
Sensitivity Adjuster
Setting for Flat/BI Amp
Setting for Flat/Bass Boost
danw2002
Post Wed Feb 08, 2006 2:55 pm
in stereo each channel can drive 2 ohms, 4 ohms mono bridged(halve its stereo rating) and mono power is just a bit more then 300, close to 340 watts. it gives out 150 watts/chn into 2 ohms. i have fixed and built over 200 of them, as i purchased carvers remaining surplus of all there parts when they closed down. i was also lucky to pic up many M4120 boards adn M4060 boards that i have fixed and made into working amps. i love the M series amps for Mid/twts and the Kmos for Bass.
hope this helps...
RynoThePirate wrote:Is the amp 2 ohm stable?
Dan Williams
carver nut,
who lives only
a few miles from
their old office....
Corvette6769
Post Wed May 23, 2007 8:09 pm
Seeking Carver Car Amplifier Specifications
If the Carver K MOS 2200 is only rated 2x100w RMS @ 4 ohms, can anyone explain why it has two 25-amp fuses, when the M-240 and M-2120 which are 2x120w RMS @ 4 ohms only come with a single 20-amp fuse?
When I A/B my K MOS 2200 against all 4 of my M-240 and my M-2120, it sure seems to be lot more powerful, effortlessly pushing my Realistic model APM-200 Audio Power Meter well past 100 RMS continuous even into 8 ohms.
I sure would welcome a scan of the specification page from a Carver owners manual for the M-240, M-2120, M-4120, PMA-2150, K MOS 2150, K MOS 4200, or especially the K MOS 2200.
danw2002
Post Thu May 24, 2007 2:54 am
Re: Seeking Carver Car Amplifier Specifications
common mistake, you have to remember that the M series amps are a magnetic power supply( carver exclusive), and are much more efficient then a standard MOsFet A/B amp, kind of between a Digital and a A/B amp in draw/power output. thus the difference in fuse inputs. the m-240/m2120 are 120 x 2 into 4 ohms, 240 mono into 8ohms, the kmos 2200 is 100 x 2 into 4 ohms, or 150 x 2 into 2 ohms, or 340 mono into 4ohms. kmos 2150 is 75x 2into 4ohms, 200 mono into 4 ohms, the kmos 4200 is 50 x 4 into 4 ohms, 75 x 4 into 2 ohms, and 150 x 2 into 4ohms.
Corvette6769 wrote:If the Carver K MOS 2200 is only rated 2x100w RMS @ 4 ohms, can anyone explain it has two 25-amp fuses, when the M-240 and M-2120 which are 2x120w RMS @ 4 ohms only come with a single 20-amp fuse?
Dan Williams
carver nut,
who lives only
a few miles from
Corvette6769
Post Thu May 24, 2007 5:37 am
Thank you for the information Dan.
Happen to have specifications for the M-4120 or PMA-2150 models?
Also, at what THD are the Carver car amplifiers rated?
Does Carver rate them THD or THD+N (Total Harmonic Distortion + Noise)?
vernonbishop
Post Thu May 24, 2007 7:41 am
I am just curious, just how long did Carver make car stereo components? I am just curious. :-k :-k
VB
danw2002
Post Thu May 24, 2007 1:23 pm
the M-4120 was two of the M-2120 together, more or less. the PMA was the same as the Kmos 2150. not sure on the thd or thd+n, but they are all very under rated amps, still to this day i run my M amps and will not get rid of them.....sweet for mid/highs.
Corvette6769 wrote:Thank you for the information Dan.
Dan Williams
carver nut,
who lives only
a few miles from
danw2002
Post Thu May 24, 2007 1:25 pm
VB, not sure on this one, would have to dig, but i would say about 10years right off the top of my head, maybe a bit more.
vernonbishop wrote:I am just curious, just how long did Carver make car stereo components? I am just curious. :-k :-k
VB
Dan Williams
carver nut,
who lives only
a few miles from
vernonbishop
Post Fri May 25, 2007 3:25 pm
danw2002 wrote:VB, not sure on this one, would have to dig, but i would say about 10years right off the top of my head, maybe a bit more.
VB
Thanks anyway. I just did not know that Carver manufacturered car stereo equipment. :idea:
Return to Carver Car Audio
