It is currently Sun May 26, 2013 2:36 am
Carver xa-25
sdvm
Post Sat Jan 31, 2009 4:38 pm
Carver xa-25
I just got my X-over. This X-over can be programmed to different -over frequences. How can i made those modules or maybe buy?
How can i see what frequency the modules are?
Does anybody know where I can purchase additional modules?
Post Sat Jan 31, 2009 10:42 pm
Re: Carver xa-25
Welcome to the forum sdvm. Those are car audio corssovers if memory serves me right and not all that commonly discussed on here. Nonetheless here is all the information I have on it.
Frequency Response ( with Subsonic Filter ) : 20Hz-20kHz (+ 1 dB ) , Subsonic Filter : -3dB @ 13Hz, Crossover Filter : Programmable 18dB/octave slope, Signal-to-Noise ( A-Wtd): 90dB (ref. To 1V rms output), Distortion: <0.1%, Input Impedance: 100 kohms, Max Input Level: 6V rms, Output  Impedance: 470 ohms, Max Output Level: 6V  rms, Operating Votage: 10- 16VDC, Dimensions: 1.5"H x 6"W x 3.25"D , Net Weight: 0.8lbs
Don't have a manual or spec sheet for these, so that is about all I can give you at this time.
sdvm
Post Sun Feb 01, 2009 5:22 am
Re: Carver xa-25
Thank you for your information.
The important question is how can i made those program modules?.
I read in the manual there are 16 program modules, 50,60,70,90,100,130,160,200,400,500,800,1000,1500,2000,3000,4000
But how can i see what kind to resistor values is what frequency
Return to Carver Car Audio
