HULU test
Start your own thread, and post videos you want others to know you like. Think of it as a way to share the things that interest you.
HULU test
Post by Toy Maker » Sun May 30, 2010 12:47 am
[youtube]b-jfrjXrOyc&NR[/youtube]
Re: HULU test
Post by Toy Maker » Sun May 30, 2010 12:59 am
AWESOME !!!! it works :) \:D/
Re: HULU test
Post by TNRabbit » Sun May 30, 2010 2:43 am
[hulu]http://www.hulu.com/watch/149174/the-si ... -me-tender[/hulu]
James, what section of the URL do we put into the hulu link?
Should look like this:
Code: Select all
<object width="512" height="288"><param name="movie" value="http://www.hulu.com/embed/NPdEQjfrMHEAYPmoVnFL-w"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.hulu.com/embed/NPdEQjfrMHEAYPmoVnFL-w" type="application/x-shockwave-flash"  width="512" height="288" allowFullScreen="true"></embed></object>
Code: Select all
[hulu]NPdEQjfrMHEAYPmoVnFL-w[/hulu]
Re: HULU test
Post by Toy Maker » Sun May 30, 2010 2:58 am
TNRabbit wrote:[hulu]http://www.hulu.com/watch/149174/the-si ... -me-tender[/hulu]
NONE OF IT.....
HULU was a little tricky. What you have to do, is to click the EMBED button on the video you are watching,
then click the COPY EMBED CODE...
Here is the trick.. this is what you will get:
Code: Select all
<object width="512" height="288"><param name="movie" value="http://www.hulu.com/embed/SBtQTuFtwbs05rNf4gSr4A"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.hulu.com/embed/SBtQTuFtwbs05rNf4gSr4A" type="application/x-shockwave-flash"  width="512" height="288" allowFullScreen="true"></embed></object>
Just like YouTube, you only need to use the video's ID code which in this case is (SBtQTuFtwbs05rNf4gSr4A)
You only use the ID and the HULU bracksts like this:
Code: Select all
[hulu]SBtQTuFtwbs05rNf4gSr4A[/hulu]
Then you get this:
Return to “(YouTube) - Create your own personal Video Profile”
