It is currently Tue Jun 18, 2013 6:58 pm
just aquired part of a system
Post Tue Nov 24, 2009 11:32 am
Re: just aquired part of a system
Welcome to the forum.
The AV505 is a nice 5 channel amp. 80 wpc with power steering. Very nice amp for driving a small HT.
The TFM 15cb are nice two channel amps. 100 wpc and you can bridge them to one channel for 280 watts of power. I have two of these in my HT. One bridged into the center and the other going into my rear speakers.
Cerwin Vegas are not the best speakers. I would stay away from them. I would need to know your budget and room size to recommend a set of speakers. Also are you going to be using as a Home Theater or 2 channel?
Post Tue Nov 24, 2009 8:15 pm
I'm not sure if you can use the preamp on the receiver to use to control the power amps or not, but I believe I would find a way to hook these items up to some cheap speakers just to see if they work or not before dumping a wad on speakers. IMO.
Post Tue Nov 24, 2009 10:42 pm
A lot of members here seem to like the Polk Audio line of speakers. I have the MB Quart Alexxa S-one that I really enjoy. If I were to look again at speakers I would research the Polk that you can bi-wire or bi-amp. Can't do that on the MB Quart. Good luck
