Looking For The Electrician (or Someone Like Him...)
Re: Looking For The Electrician (or Someone Like Him...)
Post by kingman » Wed Feb 17, 2010 6:02 am
Sorry; been in Vegas since last Friday.
Explains the last post I read with your comment at 4 a.m.!!! :lol: :lol: :lol:
fill35U
Post by fill35U » Wed Feb 26, 2014 1:43 pm
Zumbini-
I know this is an old post, but any chance you could please put up a pic of the silkscreened diagram for mono connection that's on the back of your M-1.5t?
Sounds like you've got them "strapped" in parallel mono. That must sound terrific!
zumbini
Post by zumbini » Wed Feb 26, 2014 2:11 pm
fill35U wrote:Zumbini-
When I posted this I was feeding one channel of each M-1.5t to take advantage of "power steering" (drawing power from the unused channel).
BTW: Those amps have long since been replaced with a pair of M-500t's (refurbed by BillD) with each amp driving one subwoofer in bridged mono.
Carver Gear: BillD-modified C-2 and C-11 (both w/balanced outs), CT-Seven, DTL-50, DTL-200MK2
M-200t, M-500, M-500t (x2), M-1.0t, M-1.5t (x2), MXR-130, PM-1200 (x3), PT2400, SD/A 490t, TX-2, TX-8r, TX-11b
Other: Behringer CX3400/DCX2496/FBQ3102, Furman PS-8R, Teac C-3RX and X-10R, Technics SL1200 and S-D303
Speakers: Design Acoustics DA-30 (2 sets w/extra DA-10s), Klipsch KG2.5, Legacy Super Satellites, Legacy Subs
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
fill35U
Post by fill35U » Wed Feb 26, 2014 3:05 pm
Thank you very much! Folks ought to call you "Quick Pic Zumbini", you're always ready with a helpful illustration! 8)
I was confused, because you were driving both channels and using the opposite channel's ground(black) terminal. I believe neither of which should be neessary (or have any effect).
Parallel mono has advantages, but also pitfalls! I'm also more inclined to run with just one channel, unless the load tends to low impedance.
Post by Snoop65 » Wed Feb 26, 2014 3:42 pm
Nice system!!!!
zumbini
Post by zumbini » Wed Feb 26, 2014 3:49 pm
Snoop65 wrote:Nice system!!!!
Thanks Snoop! It's my little slice of Carver heaven.
zumbini
Post by zumbini » Wed Feb 26, 2014 3:57 pm
fill35U wrote:....I was confused, because you were driving both channels and using the opposite channel's ground(black) terminal. I believe neither of which should be neessary (or have any effect)....
I was confused too Phil #-o (about needing to feed both channels).
Using the opposite channel ground was necessary because the "correct" binding post was damaged. No biggie since it's a common ground amp.
Post by OconeeOrange » Wed Feb 26, 2014 4:00 pm
Excellent !! Reminds me of KingMan's place.
My crap reflects the RedNeck I am, so go figure.
fill35U
Post by fill35U » Wed Feb 26, 2014 4:13 pm
zumbini wrote: Using the opposite channel ground was necessary because the "correct" binding post was damaged. No biggie since it's a common ground amp.
Thanks, it all makes sense now! :)
Those binding posts really were a weak point on those models. I never had a problem with the ones on my TFM-45's, so they must have listened to the customers who clamored for an improvement.
I briefly toyed with the idea of running bridged M-1.5t's (series bridged with simple mods), but then I decided to go with PM-1.5a's instead - younger, tougher, slightly more power, lots more features, but still with the Anthracite look I wanted. Still, I'm finding it difficult to give up my remaining M-1.5t, she's so stately with her bold and simple face...
And nice rack! =D>
Post by angelod307 » Wed Feb 26, 2014 4:36 pm
Now i am a little lost . Do the 1.5 amps not share a common ground? And if they do, why would you not invert one channel input and then feed off both positive outputs with one being ground due to the invert? Or if you are using the ground of one channel and simply using a y adaptor, then that would mean that one channel is inverted at the inputs and outputs? Are these the amps that have issue running polk sda type speakers?
Post by angelod307 » Wed Feb 26, 2014 4:38 pm
Oh, i missed that. So, then all you have is one channel with a touch more headroom right?
zumbini
Post by zumbini » Wed Feb 26, 2014 4:39 pm
fill35U wrote:I briefly toyed with the idea of running bridged M-1.5t's (series bridged with simple mods), but then I decided to go with PM-1.5a's instead - younger, tougher, slightly more power, lots more features, but still with the Anthracite look I wanted. Still, I'm finding it difficult to give up my remaining M-1.5t, she's so stately with her bold and simple face...
I recapped both of my M-1.5t's a few years ago. Kept one as a spare and gave the other to my son for his system (M-1.5t/CT-7/DTL-200MK2).
I agree with your assessment of the pro version. I'm using 3 PM-1200's in my PA rack (along with a PT2400) and they kick ass.
Post by angelod307 » Wed Feb 26, 2014 4:40 pm
Nice system!!!!
Sweet! Wow that a hell of a audio collection of disc. Bet is sounds as good as it looks.
zumbini
Post by zumbini » Wed Feb 26, 2014 4:45 pm
angelod307 wrote:Using the opposite channel ground was necessary because the "correct" binding post was damaged. No biggie since it's a common ground amp.
That's correct Angelo. The owner's manual suggests about 30% more power is available that way, up to the limit of the power supply (1200W)
zumbini
Post by zumbini » Wed Feb 26, 2014 5:01 pm
angelod307 wrote:Sweet! Wow that a hell of a audio collection of disc. Bet is sounds as good as it looks.
Thanks Angelo. It's not perfect (yet) but it'll do in a pinch. :lol:
I have considerably more LPs in another rack in the next room.
Here's a shot of the entire wall of my man cave.
The PA speakers are part of the band setup on the other side of the room.
