Gene C's System
Re: Gene C's System
Post by jjptkd » Fri Feb 21, 2014 4:15 pm
Yep, had one of those at one point too:
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
fill35U
Re: Gene C's System
Post by fill35U » Fri Feb 21, 2014 4:45 pm
jjptkd wrote:
fill35U wrote:Thanks for the nudie pics of the -7t. I knew they were M-1.5t derivatives, but I didn't realize they kept the same circuit boards as well!
Actually the 7t & 9t use the same parts as the M-4.0t & TFM 42 / 45
Thanks for the clarification! For some reason I had thought the 7t predated the M-4.0t, when in fact M-4.0t was released almost a year earlier. #-o
It looks like they took the M-4.0t's schematic and just drew in the extra parts!
And your main amps all have matched sound. 8)
Gene C
Re: Gene C's System
Post by Gene C » Fri Feb 21, 2014 4:50 pm
jjptkd wrote:Yep, had one of those at one point too:
Nice! That looks exactly like my black 4.0t in the closet.
Here's the other stack.
Living room...Sunfire TGP-III 11.4 setup 4 Silver Seven t's/Infinity Kappa 9A (main)/ 4 TFM-45's/ CRS3 (main) /Sunfire CRS3C (center)/Pro-Ject RPM 5.1 v2/Jolida JD-9 II /Apple TV/Wadia 171i/SD/A-490T /WA6/Infinity PS-312 sub & Sunfire Signature Sub (rear)/2 Martin Logan Dynamo 1000 watt subs (front)/AV-806X/4 Infinity C255ES bi pole speakers for sur, sur back and side axis/70" Sharp Aquos LC-70LE733U/Oppo BDP-95 Blu-ray/Douglas Interconnects & 9ga speaker cable.
Garage... CT-17/M-0.5t/TFM-15cb/AV-64/AudioSource EQ Eight Series II 4 Infinity micro sl speakers/2 Martin Logan Motion 4/Infinity Entra 12" Sub.
Gene C
Re: Gene C's System
Post by Gene C » Fri Feb 21, 2014 4:53 pm
Minus 1 amp board, same amount of output transistors. Which makes them beasts. :D
EndersShadow
Re: Gene C's System
Post by EndersShadow » Fri Feb 21, 2014 4:55 pm
Gene, you aiming for Kingman status as a Carver hoarder?
PS LOVE my 705x, thought wish it looked purtier...
And the M1.0t I have needs a new faceplate someday......
Re: Gene C's System
Post by Magnaryder » Fri Feb 21, 2014 5:31 pm
Nice rig Gene, very nice!!! Spin the vinyl Bro'
Gene C
Re: Gene C's System
Post by Gene C » Fri Feb 21, 2014 5:36 pm
Magnaryder wrote:Nice rig Gene, very nice!!! Spin the vinyl Bro'
Thanks Ray! Yeah todays been a combo day. Lately it has been strictly vinyl, but had to fire up some CD's a little while ago. The SD/A-490t was getting a little lonely.
Re: Gene C's System
Post by kingman » Fri Feb 21, 2014 5:50 pm
Nice Gene!!! You may want to consider moving the 490t to the top position in the stack because of the heat output generated by the tubes.
Gene C
Re: Gene C's System
Post by Gene C » Fri Feb 21, 2014 6:17 pm
kingman wrote:Nice Gene!!! You may want to consider moving the 490t to the top position in the stack because of the heat output generated by the tubes.
Those photos that I posted a few hours ago Wayne are of spare equipment in my closet. If you saw the photos (a thread or 2 back) You would see the 490t is on top of the TGP-III. :)
Re: Gene C's System
Post by kingman » Fri Feb 21, 2014 7:17 pm
My dumb!!! ](*,) Detail deficient disorder....... :lol:
Re: Gene C's System
Post by Snoop65 » Fri Feb 21, 2014 7:31 pm
It took some getting used to, Steve Ford turned me on to the 2M black. Hell who am I kidding Steve fueled my Vinyl frenzy, he was a huge help and influence.[/quote]
Excellent! I enjoy my digital but I prefer vinyl. You might end up feeling the same way. :D[/quote]
Yeah, I find myself listening to more vinyl than digital when I'm home. Just meant the cart took some getting used to. Had a Denon DL-110 cart before I liked very much, which is why the Ortofon took a little getting used to.[/quote]
I'm sure your new cartridge is going through a break in period too.
Gene C
Re: Gene C's System
Post by Gene C » Fri Feb 21, 2014 8:00 pm
Snoop65 wrote:I'm sure your new cartridge is going through a break in period too.
200 hours is the recommended break in time, my old stylus was already broken in when one day it mysteriously broke. :shock: The new one doesn't even have 100 hours on it yet, but know what they sound like broken in. :D
