Hello Everyone~ Glad to have found this Carver site!!
- Newbie
Been searching the web high and low for some info on the way to connect this Carver PT-1800 into my system of home Audio~
Currently running two Silver 7-Ts into a pair of JBL speakers and my brain is the Carver C-19 preamp. just picked up the PT-1800 and PT-1250.
I have another pair of JBL speakers collecting dust and would like to air them out with the PT-1800~
*****Do I get XLR to RCA adapters and run the RCA cables to the second set of MAIN AMP Outputs on the C-19?
Any Help would be Greatly Appreciated!!
Thank You and Hello to everyone~~
- TNRabbit
- R.I.P. Friend
- Contact:
Re: Hello Everyone~ Glad to have found this Carver site!!
You can TRY that.....sometimes that leads to ground loop hum.
- kingman
- (pair of) SILVER-7 TUBE AMPs
Welcome to the forum!!!
- helicopterpilotdoug
- (pair of) SILVER-7t's
- Contact:
Welcome to the forum. I posted this in another thread where you asked about it, but here ya go again. The best way to do this is with something like this, a Balun. This will take your unbalanced RCA connection from the c-19 and transform it to a balanced output to go to your PT-1800. Can get you one for $175.
- TNRabbit
- R.I.P. Friend
- Contact:
What Doug said is ideal.
- Zoot Horn
- SILVER-7 TUBE AMP
Welcome!
Living Room/main System:
Onkyo tx nr 545
Carver Amazing Silvers
Carver SD 390t
Technics SL 1950 Turntable
Polk Audio outdoor speakers wired to deck
Polk audio wired to pool table room
Basement/system 2:
Carver MXR-130
Teac reel to reel
BBE 362 Sonic Maximizer
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Pioneer 100 disk changer
Garage system:
Pioneer VSX something?
Polk Audio 2500
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
- Newbie
Thanks soooo much for all the welcomes!! Thanks for all the feedback!~ I Appreciate all the time! You guys have helped out more than you can imagine~
*****I Can't wait to hear the SILVER 7 T's, PT 1800 and the four JBL speakers!! Thanks again~~~
Welcome
- TNRabbit
- R.I.P. Friend
- Contact:
I would highly suggest that you FUSE your speakers...cperce6685 wrote:Thanks soooo much for all the welcomes!! Thanks for all the feedback!~ I Appreciate all the time! You guys have helped out more than you can imagine~
