New speakers
Re: New speakers
Post by frenchguy » Mon Jun 11, 2018 8:59 pm
You can PM ED (SEA} on this forum, he rebuilds the Carver ribbons & does great work! just got 2 for my silvers earlier this year, they sound great! you can also PM helicopterpilotdoug on this forum as well! 8)
cring08
Re: New speakers
Post by cring08 » Mon Jun 11, 2018 9:23 pm
Thanks guys!
Living Room/main System:
Onkyo tx nr 545
Sunfire CRM2’s
Technics SL 1950 Turntable
Little Bear phono pre
Polk Audio outdoor speakers wired to patio/pool
Bedroom system starting
Carver Amazings (ready to send to sea for ribbon rework)
Garage system 2:
Carver MXR-130
Teac reel to reel
BBE 362 Sonic Maximizer
Nikko eq2
Cerwin Vega HED's
Pioneer 100 disk changer
Pioneer VSX something?
Polk Audio 2500
Re: New speakers
Post by kingman » Tue Jun 12, 2018 4:56 am
Thanks guys!
Chris...I sent Doug's # to you. He is rarely on the forum anymore. Good luck!
Re: New speakers
Post by jjptkd » Tue Jun 12, 2018 8:12 am
While the AL-III's and Sunfire ribbons are both nice they do not compare to the Amazings that you already have, I'd take the suggestions here and have both of your ribbons repaired rather than spend more money only to take a step back in quality.
Oppo Sonica DAC
Sunfire TG-IV
Sunfire 325x2
Customized Klipsch RF-5's
Coming soon: Carverfest 20 watt Amp
Robert R
Re: New speakers
Post by Robert R » Tue Jun 12, 2018 10:10 am
The AL-III and the Silver Amazings both used identical, interchangeable 48'' ribbons. Differences in sound can only result from the angle they sit at and crossover variations.
I'd certainly keep those Silvers at this point, and get both ribbons rebuilt. Both, for two reasons: the new ribbon material is thicker and a different impedance than the stock factory ones, and thus has slightly different voicing. And the still-functioning ribbon probably is on its last legs, anyway.
As I've said more than once, don't change out just the worn out front brake pads on one side...
RR
cring08
Re: New speakers
Post by cring08 » Tue Jun 12, 2018 12:26 pm
I just spoke w Doug, and I believe I am going to pickup the Sunfire speakers, thanks Wayne!
I am also have an email in to Ed on having the ribbons repaired on the Amazings.
Onkyo tx nr 545
Sunfire CRM2’s
Garage system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Polk Audio 2500
Re: New speakers
Post by kingman » Tue Jun 12, 2018 5:41 pm
Bravo!!! =D> 8) \:D/
Re: New speakers
Post by jjptkd » Wed Jun 13, 2018 5:55 am
Congrats, those are very nice speakers! I don't see a subwoofer listed in your main setup in your signature, those little ribbon speakers are very dependent on a quality sub or two to get the big sound out of them I believe they are only rated 100hz and above just so you know.
Oppo Sonica DAC
Sunfire TG-IV
Sunfire 325x2
Re: New speakers
Post by Don » Wed Jun 13, 2018 4:01 pm
Was thinking the same thing. Will need a quality sub Chris.
cring08
Re: New speakers
Post by cring08 » Wed Jun 13, 2018 8:49 pm
I currently have a Klipsch SW15 powered sub that should work until I can find a Sunfire sub.
I am excited to get this rolling!
Onkyo tx nr 545
Sunfire CRM2’s
Garage system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Polk Audio 2500
cring08
Re: New speakers
Post by cring08 » Thu Jun 14, 2018 12:07 pm
Any opinions on these two subs would be appreciated as well...
https://fortmyers.craigslist.org/lee/el ... 19604.html
https://tampa.craigslist.org/pnl/ele/d/ ... 76843.html
Thanks!
Onkyo tx nr 545
Sunfire CRM2’s
Garage system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Polk Audio 2500
Re: New speakers
Post by kingman » Thu Jun 14, 2018 2:14 pm
Thanks!
The EQ at $499 is the way to go.
Re: New speakers
Post by BrianT » Thu Jun 14, 2018 4:26 pm
Thanks!
Thats the way I would do it, lets hope the mic is with it.
Robert R
Re: New speakers
Post by Robert R » Thu Jun 14, 2018 4:45 pm
Yes, the EQ. its about a half-hour from my Florida house.
Expect it to need some new capacitors anytime soon, if not right away. After running it, shut off all input to it; it should stay 'on' for around 10 minutes, at which point you'll hear a soft staccato sort of pop, telling you it has automatically shut down. The sooner the shutdown, the worse shape the caps are in. At some point it gets so bad that it will only turn on at all when there is a huge bass drum hit, and you get to hear the last half of that, after which it shuts off again. This is something I can fix.
cring08
Re: New speakers
Post by cring08 » Tue Jun 19, 2018 6:28 pm
The speakers are on the way! Thanks Doug! (And the referral Wayne)
Still waiting for a word on ribbon repair.
I think I am going to try these out with the Klipsch sub for awhile, since I just started back to work this week.
Thanks again for all of your help!
Onkyo tx nr 545
Sunfire CRM2’s
Garage system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Polk Audio 2500
