Re: It all started in 1980...
It is currently Fri May 24, 2013 9:15 am
TNRabbit wrote:I joined the USAF in 1980 as well, but I had a wife & small child within a couple of years & while I lusted after Carver gear, I was never in a position to afford it until the past couple of years (I've made up for lost time!)...thanks for the story!
SteveFord wrote:Great read, hope you get in a position to build your second system soon.
lawdog10231 wrote:Welcome aboard! I probably have the exact opposite to your trioded tube sound. I'm driving original Carver Amazings (2 ohms) with two Sunfire 300x2 amps in a vertical biamp which gives me 2400 watts per channel and I'm able to use the high current taps for the ribbons and high voltage taps for the woofers. I can't imagine anything sounding better...
But I have friend who has those real expensive German horn speakers which he drives with a 10 watt triode tube amp and when I heard his system play chamber music I was almost converted.
This is probably the best board on the web. I think you'll be happy here.
BillD wrote:There was only one thing in Jim's story that confused me. I didn't think the M-500t was available in 1980. As I recall, the C-500 and C-4000 were introduced in late 1979 (I bought that pair January 13, 1980). The M-400 (cube) was introduced in 1980 and later that year the M-500 (sans t). I didn't think the "t" showed up until 1981.
