It is currently Sat May 18, 2013 5:48 am
ViperZ's Carver stuff
ViperZ
Post Wed Feb 04, 2009 6:07 pm
I finally got my Carver gear together for a 2.1 setup:
- Carver TFM-24 amplifier
- Carver C-1 holography preamplifier
- Magneplanar Magnepan MG-II planar speakers
- Velodyne ULD-15 subwoofer
- Dual 1228 TT
I also have Carver CT-28v, which I have no use for at this point... and looking at getting M-400t cube for a new project...
Post Wed Feb 04, 2009 9:45 pm
Re: ViperZ's Carver stuff
Rock on Viper! How do you like the sound? Does that combo work out pretty good?
ViperZ
Post Wed Feb 04, 2009 10:17 pm
To be honest, I still need more time to listen... When we were testing/tuning the TFM-24, we used CT-28v, and those two sounded very nice together.
I know, C-1 has been praised a lot, but I haven't listened to it enough to make a judgment. Also, if/when I'll get a cube, I'll play with C-1/M-400t combination, but right now M-400 is slated for the subwoofer duty. In case if it will sound too get, I may downgrade TFM-24 to the sub :).
Post Wed Feb 04, 2009 11:18 pm
Cool! I like looking at the Carver stuff for sure, but could you post more pictures of the Magneplanar Magnepan MG-II planar speakers
Curious what they look like in your set-up? Thanks
ViperZ
Post Thu Feb 05, 2009 12:15 am
Jag_97470 wrote:Cool! I like looking at the Carver stuff for sure, but could you post more pictures of the Magneplanar Magnepan MG-II planar speakers
I am currently re-finishing the frames for Maggies (after rebuilding tweeters, replacing crossover capacitors with Solens and installing new socks), that's why I only listened to them with C-1 for a bit.
Here is a pic of ULD-15 in the StudioLab setup:
- rebuilt the box (brand new bottom 3/4" MDF plate, mahogany finish)
- replaced speaker surround
- completely replaced all electrolytic capacitors in the amplifier (power supply and signal path).
ULD-15 is on the left of the StudioLab sub:
ULD-15 close-up:
Maggies in their current state (waiting for the warm weather to finish the frames):
I think I'll finish the Maggies frames in mahogany too, to match the Velodyne.
Ah, Velodyne controller/amp (2nd shelf):
Post Thu Feb 05, 2009 12:43 am
It looks like you are in the same situation as me. You need more room for those babies to breathe. ](*,)
Post Thu Feb 05, 2009 1:05 am
Thanks ViperZ! Those pictures are Awesome! Looks like your working your way to great sound!!
Post Thu Feb 05, 2009 2:15 am
VERY nice, but doesn't your TT skip, just a LITTLE, sitting on that sub?!? :lol: :lol: :lol:
skip
aka (Sasquach)
Post Thu Feb 05, 2009 9:01 am
Nice rig for sure. Ask Magnarider if a sub puts out any vibrations with something on top. :D
Sasquatch
Post Thu Feb 05, 2009 9:20 am
skip wrote:Nice rig for sure. Ask Magnaryder if a sub puts out any vibrations with something on top. :D
Are you referring to THIS pic?!? :D
ViperZ
Post Thu Feb 05, 2009 11:27 am
TNRabbit wrote:VERY nice, but doesn't your TT skip, just a LITTLE, sitting on that sub?!? :lol: :lol: :lol:
Nah, it's there just for photos ;). At that time I had StudioLab sub hooked up instead of the Velodyne, so Velo was being used as a stand for the TT. The problem with hooking up the StudioLab sub to TFM-24 (each driver in the sub is separate and is 4 Ohms :lol: ) - you see that 32" LCD sitting on top of the sub? Well, it wanted to jump off a few times...
Post Thu Feb 05, 2009 7:25 pm
Great to see your set up...I'm thinking those Maggies could use some additional juice...the 24 is nice, but you can never have enough power for ribbons!
Dreamer
Post Thu Feb 05, 2009 8:37 pm
Martin Logan's top-end sub, the Depth-i, is so anti-resonant, that you can play performance-level orchestal music through it, and set a nickel on-edge on the top, and it won't move...
http://www.us.martinlogan.com/speaker_i ... pth_i.html
When I heard a dealer say this, I called "shenanigans", and thought it was COMPLETE BS, but then he did it. That thing would rock the house, was tight-musical, and accurate as heck, and that nickel just stood there, on top of the Depth, not even so much as a wobble. Blew my mind...
ViperZ
Post Thu Feb 05, 2009 8:44 pm
kingman wrote:Great to see your set up...I'm thinking those Maggies could use some additional juice...the 24 is nice, but you can never have enough power for ribbons!
No ribbons in my maggies :) These are model MG-II: both, tweeter and mid are on the same panel.
ViperZ
Post Thu Feb 05, 2009 8:45 pm
Dreamer wrote:Martin Logan's top-end sub, the Depth-i, is so anti-resonant, that you can play performance-level orchestal music through it, and set a nickel on-edge on the top, and it won't move....
Well, maybe in 20 years I'll be able to afford the one that I can get and rebuild :)
