It is currently Thu May 23, 2013 11:38 am
Recent Upgrade - Whoo Whoo!!
Post Wed Jul 22, 2009 11:43 pm
Re: Recent Upgrade - Whoo Whoo!!
Well when I upgrade to a set of MKIV's you can buy my AL III's. \:D/
Post Thu Jul 23, 2009 3:17 am
Those poor fish!!!!!!!!!!!!!!!! That`s just wrong.
Post Thu Jul 23, 2009 10:15 am
They don't seem to have a problem with it. They swim around the same way with or without the stereo on. Though when I added the Sunfire Sub and it starts to hit hard they do tend to get a bit jumpy.
icravcarver
Post Thu Jul 23, 2009 9:01 pm
Do a lot of you with the AL III's think they need to be run with a subwoofer, or are they adequate without one? Just curious. I've heard the Amazings (again thanks Beemers), but not the AL III's.
Inquiring minds want to know!!
OCCD claims another victim!!
Carver Gear: MAIN SYSTEM: TFM-55; C-16; SD/A-490t; TD-1770; BEDROOM: HR-772
Non Carver Gear: MAIN SYSTEM: Dual CS-530 TT w/Ortofon Super OM10; POLK SDA-1C's; Phillips CDR-775 CD Burner; BSR EQ-300; BEDROOM: T.B.A.
"I may be poor, but I am rich in sound!!"
Post Thu Jul 23, 2009 11:25 pm
Al-IIIs can use a little help in the last octave (20Hz to 40Hz)
Post Fri Jul 24, 2009 12:15 am
BillD wrote:Al-IIIs can use a little help in the last octave (20Hz to 40Hz)
That is about were I have my sunfire crossed over. I would suggest a sub with them but I don't think your really need one. It is personal preference.
Post Fri Jul 24, 2009 9:57 am
Yeah, I cross mine in about 50Hz.
Post Fri Jul 24, 2009 11:03 am
I disagree with BillD; the AL-IIIs go lower than MOST full-range speakers (properly placed, you shouldn't have any trouble hitting 24 hz notes), so I disagree that they NEED a sub. 30 hz is NO problem for them. A GOOD amp will do more for the lower register with the AL-IIIs.
THAT SAID, I use a sub with mine to supplement only the lowest frequencies & take some of the heat off my amps & the AL-IIIs (crossed over @ 40 hz and running the AL-IIIs biamped; Bill & I have pretty much the exact same setup).
Post Fri Jul 24, 2009 1:26 pm
Gary, remember that you don't have "stock" woofers.
Hot Rod!!
stereo_buff
Post Fri Jul 24, 2009 6:27 pm
In the main, I would agree. While I was using AL-IIIs, I set up my (Sunfire True Sub Mk. II) sub crossover control for 40 Hz; that seemed to work OK.
madmike46
Post Tue Aug 25, 2009 10:16 pm
Real nice, I sure the fish are used to the sound.
Post Tue Aug 25, 2009 11:47 pm
thuffman03 wrote:They don't seem to have a problem with it. They swim around the same way with or without the stereo on. Though when I added the Sunfire Sub and it starts to hit hard they do tend to get a bit jumpy.
Hey, if you turn out the light and put on a Black light, do the fish light up? And you know how fish always move their mouths sucking in water? I bet it looks like they are singing to the music! Do they have ear doctors for fish? :lol: :lol: Just messing with ya! Actually pretty cool! ;)
