It is currently Thu May 23, 2013 9:24 pm
CARVER PM 1200
TFM Carmine
Post Tue Apr 05, 2011 7:25 pm
Re: CARVER PM 1200
TFM Carmine wrote:I think I blew the CV 18" sub so I now use the empty speaker cabinet for my cats lol, they love it. I even took the carrying handles off it they go in & out through the handle holes or the large woofer hole, I just don't think it was worth buying a woofer for :-({|=
:lol: :lol:
I refer you to this thread:
TNRabbit wrote:If the sub is 8 ohms, you can safely bridge the amp into it. Just remember 1000 watts PEAK usually means you can hit that for a fraction of a second every several minutes, not constantly~
RMS (i.e.constant) load is usually about 1/3rd of the peak or less. Voice coils heat up & require cool-down time between bursts or they overheat & begin melting together. It doesn't necessarily happen all at once. It can begin with a few coils melting together, dropping the impedance, and as that happens more & more, you eventually end up with either a direct short or the impedance gets so low it triggers the amp to shut down.
yup I think it melted the voice coil a bit during bridged mode, I probably should have ran just 1 channel lol
CT-29v,TFM-55, PM 1200
Post Tue Apr 05, 2011 8:23 pm
Re: CARVER PM 1200
If I may suggest.... Get your hands on a JL 13W7 Check your local CraigsList, they pop up all the time...
Grab a used one and beat the living shit out of it !!! It will take everything that amp will throw at it.
We have (2) of them in the living room.... The 1st thing people say is: HOOOOLYYYY SHIT !!!!!!!!!!!
Or in Tom's case..... WHAAAAT THE FUCKKKKK ????
Better Living with: Mo' Betta' Bass !!!! =D>
TFM Carmine
Post Wed Apr 06, 2011 10:06 am
Re: CARVER PM 1200
good advice I,ll check it out ](*,)
Return to Carver Pro
