Finally plugged in my PT 1800 after a YEAR...
Today, I got a stick up my Arse and wanted to plug it in and see if it worked at all. First we put it in Dual mono, only the left channel worked... Then we turned it off, put it on stereo mode, turned it back on, and then nothing... Then we tried series mono, and nothing again... Turned off the amp and put it back on stereo mode and jiggled all the wires (just in case) and turned it back on.
IT 'EFFIN WORKED!!!!!
Come to find out, the Right channel XLR chassis mount is loose or something and it was making a bad connection... I plan on getting some new chassis mounted XLR connectors and my father and I are going to fix it!!
Also, Beemer, I still have not put the signed faceplate on.....
](./images/smilies/eusa_wall.gif)
(Stereo System)
Carver Pro PT-1800
Sunfire Prototype TGA-2375
Carver TX-2 Tuner (not used)
