Record Clamps or Stabilizer Weights?
Vinyl Discussion
SteveFord
Post by SteveFord » Thu Oct 16, 2008 8:37 pm
Does anyone have experience with record clamps or the simple stabilizing weights that slip over the spindle?
Well Tempered Labs (the old company) makes a clamp but I can't get ahold of the fellow who carries the product.
The Sota I clamp may work with my turntable so would I be better off with that or just go with a stabilizer? Is there anything to worry about with the extra 14-16 ounces of the stabilizer weight putting a strain on the belt and motor?
Upstairs:
VTL MB-250 Signature monoblocks, Sonic Frontiers SFL-2 preamp, HHb BurnIt Plus, Well Tempered Labs Classic, Ortofon 2M Black, Jolida JD-9 Phono Preamp, Sherwood S3000-IV tuner, VPI-17, Jolida JD-100, AKG 701, Beyerdynamics 881, NHT SW1-P subwoofer and amp, Magnepan 1.6, APC H15
Downstairs:
VTL DeLuxe 300 Monoblocks, Harman Kardon F500x tuner, Sonic Frontiers SFL-2 preamp, Jolida JD-100, Oppo 981, Otari MX5050 BII, SVS SB-12 subwoofer, Magnepan 3.6
In Storage:
Stax Sigma headphones, signed DTL unit, Magnepan MMGs, Carver TX-11, TX-11a's
Re: Record Clamps or Stabilizer Weights?
Post by TNRabbit » Thu Oct 16, 2008 10:11 pm
BlueMDPicker has the best one I've ever seen; maybe he'll chime in....
I don't think you can see it in this pic: Image
Mike?
Post by OBI56 » Thu Oct 16, 2008 11:13 pm
Since the weight is close to the centre of the record, it should have a negligeable effect on both the motor and the belt (little ot no change in the total inertial mass). Where is will have an effect will be on the platter centre thurst bearing (so will a clamp BTW). I use the Alchemist stabilizer which works really well and is much lighter than the 14 to 16 ounce range you quoted. It has a spirit level on it which is great for acheiving perfect levelling of your TT, but the stroboscope ring is unfortunately only claibrated for 50Hz lighting, not our standard 60Hz.
SteveFord
Post by SteveFord » Tue Oct 21, 2008 8:40 am
The Well Tempered Clamp finally showed up - it's knurled, black anodized aluminum and threads into the spindle. Pretty clever.
Weighs 109.5 grams, 2.5" diameter if anyone's interested.
Upstairs:
Downstairs:
In Storage:
RichP714
Post by RichP714 » Fri Oct 31, 2008 2:33 pm
I used to have one of these vacuum platters: very nice, but I can't find them around anymore and all I have left is the manual.....
Return to “Vinyl”
