It is currently Wed Jun 19, 2013 12:09 am
bi-amp / bi-wiring speakers
• Page 1 of 3 • 1, 2, 3
Sorry for being uneducated, but I have a question concerning bi-amping my Polk LSI-9 speakers. They have the double bridged posts. I have two PM-300 amps. I would like to run the bass drivers on one amp and the mid/high on another. On bi-amp capable speakers, are the crossovers seperated or do I need an external crossover to filter the signals from each amp?
Remove the binding post straps from the binding posts. Hook one amp to the bottom posts on each speaker, the other amp to the top posts. No external crossover is needed.
Correct me if I'm wrong, but isn't the whole idea of bi-amping to clear up each (bottom/top) section of the audio spectrum by only running those particular frequencies thru the amp? You are wasting bass energy in the treble amp if you run full spectrum sound and vice versa.....????
TNRabbi wrote:Correct me if I'm wrong, but isn't the whole idea of bi-amping to clear up each (bottom/top) section of the audio spectrum by only running those particular frequencies thru the amp? You are wasting bass energy in the treble amp if you run full spectrum sound and vice versa.....????
That's the best way to do it. But Carver amp and speaker systems are happier being bi-amped rather than being bridge amped. To do this some speakers will need to have their woofer and tweeter crossover sections separated. In this passive bi-amp mode, the tweeter amp does not produce any woofer power (woofer voltage yes, power no).
Maybe I'm missing something here, but how do you run particular frequencies thru an amp?
Speedskater wrote:mikekohut wrote:What kind of amplifiers are you using?
Which of use four?
HUH???
F1nut wrote:TNRabbi wrote:Correct me if I'm wrong, but isn't the whole idea of bi-amping to clear up each (bottom/top) section of the audio spectrum by only running those particular frequencies thru the amp? You are wasting bass energy in the treble amp if you run full spectrum sound and vice versa.....????
Active crossover BEFORE the amp...
I am still confused. Will removing the bridging strip on the speaker posts seperate the crossovers thus allowing only lower octave signals through the bass speaker and higher through the tweeters, or do I need an external crossover between my C1 and each PM300 that filters out high or low signals before they reach the amp and speakers? If the latter, does anyone have any reccommendations for a processor unit that will handle this task? Thanks to all for the advice and guidence.
My two cents
Skip, I run my Polk RTi10's with the binding post straps removed in my current system, running all of the speakers within the speaker, but the tweeter. It sounds like I am getting all of the frequencies that I want. If this confused you more...disregaurd, I have a "crack baby system".
I have bi-wired Polk RT-800's and the Rti10's using all sorts of configurations and amps and I have never heard of a frequency loss or overemphasis when doing so........which leads me to believe that F1nut is correct in the first response that you recieved on this subject. Trust me when I say F1nut knows a thing or two about Polk speakers.
The best thing I ever did was experiment 10,000 plus times [kidding] to see what combination came up with the best sound. Just try to keep in mind where the volume knob will be in relation to how many watts your speakers are rated for because you will be changing the "pull" that the speakers put onto the amp.
If I am wrong with any of this [anybody], let me know. One can always learn.....and if I learn, then you will be helping me improve my sound also.
TNRabbi wrote:F1nut wrote:TNRabbi wrote:Correct me if I'm wrong, but isn't the whole idea of bi-amping to clear up each (bottom/top) section of the audio spectrum by only running those particular frequencies thru the amp? You are wasting bass energy in the treble amp if you run full spectrum sound and vice versa.....????
I've never heard of that and it makes no sense to me.
skip wrote:I am still confused. Will removing the bridging strip on the speaker posts seperate the crossovers thus allowing only lower octave signals through the bass speaker and higher through the tweeters
Yes. Any speaker that has a dual set of binding posts will work the same, not just Polk speakers.
F1nut wrote:Remove the binding post straps from the binding posts. Hook one amp to the bottom posts on each speaker, the other amp to the top posts. No external crossover is needed.
F1-nut gave you the correct answer.
The straps on the back of your speakers, that bridge the speaker binding post just gives you an external link "outside of the box if you will" to do the samething that happens inside the box.
When you bi-amp and remove the strap and use two amps one for the highs and one for the lows " as far as the speaker is concerned" It wont change anything about the crossover, for all the speaker knows its still being fed by one amp!
I asked what kind of amps you are using because if they are the same amp you can, as I have recently learned, vertically biamp your speakers. I am in the process of trying this out when I get a moment (currently I am horizontally biamped). From what I have gathered on this site, outside of the extra work of fabricating an effective external crossover, the vertical method is the most preferred biamp method because it spreads the demands of the bass-hungry woofers across two separate power supplies.
Horizontal = one amp powers the woofers of each spkr and the other amp powers the highs
Vertical = Each amp is run in stereo mode and each channel of each amp is dedicated to either the highs or lows
