Re: Sunfire CRM2s
I'm gonna email another guy that's an authorized dealer who also sells B-Stock.
I'll ask him about the CRM2C (for me) and the CRS3C (for you).
When I get a response I'll post the information on this thread.
UDUB Football!
It is currently Tue May 21, 2013 11:06 pm
BillD wrote:My bigger interest was the CRS-3C, but they're kinda pricey. Right now I'm running an M&K S-125C
maybe CRM2s? What is their power rating?Jag_97470 wrote:What do you guys think about using the CRM2s for main L/R speakers? I have not heard them and would assume a sub would be needed, what you think? The only reason I'm asking is my daughter asked me the other day what would a good shelve speaker be for her small apartment and I thoughtmaybe CRM2s? What is their power rating?
Jag_97470 wrote:Thanks James, they almost sound more suited for a larger room maybe that must be put on stands. I guess they could be put on stands in a small apartment. Then you have the added expense of the sub. Doesn't sound like they would be practical for her. Thanks for your review. Any suggestions for a somewhat full range bookshelf speaker? Thanks
Jag_97470 wrote:. Any suggestions for a somewhat full range bookshelf speaker? Thanks
TORO3 wrote:Avalon gave me a call back. He stated that his distributor told him that the CRM2C was discontinued a couple months back.
I guess this means that Sunfire is no longer producing the CRM2C....
Huh.
OCCD wrote:Jag_97470 wrote:What do you guys think about using the CRM2s for main L/R speakers? I have not heard them and would assume a sub would be needed, what you think? The only reason I'm asking is my daughter asked me the other day what would a good shelve speaker be for her small apartment and I thoughtmaybe CRM2s? What is their power rating?
If you don't mine I will answer from my point of view. First the CRM-2's are 400 watts Power handling. They get damn loud! One must also get a sub, No way around it. Putting them on a shelf Kills there Quality sound stage - You may get by better with CRM-3's but not 2's = They need a stand and need to be set-up for proper listening and it takes a little space to get em right so again the 3's are more suited here as well but if all is done correct then you are rewarded with the most amazing speakers in there size made and for that matter almost any speaker! Done right the CRM-2's blow away the 3's in imaging and are Made with S/H in mind![]()
They have a Loooooong break in period and are a bit harsh till then after that oooooOOOOOHHHH YEAH!![]()
I would like to hear what others out there have to say on them as well...
OconeeOrange wrote:OCCD wrote:Jag_97470 wrote:What do you guys think about using the CRM2s for main L/R speakers? I have not heard them and would assume a sub would be needed, what you think? The only reason I'm asking is my daughter asked me the other day what would a good shelve speaker be for her small apartment and I thoughtmaybe CRM2s? What is their power rating?
Maybe the 2s blow the 3s away, but I doubt that.![]()
The CRS-3 is a good speaker. Have you heard them used with the power they require?
The 3s cut off at 80hz, so you do need a sub. Maybe the 2s are better for home theater, but I doubt it. No way they could do music as well as they just don't have the equipment inside.
The CRS-3 have a switch on the back for whether they are near or far from a wall. Mine are mounted to the ceiling. I flip the switch some, but I guess better ears than mine will be needed to hear the difference.
I love them both the same and each have there strengths "Full" or "imaging" MOSTLY thanks for speaking your mind on the matter and saying you don't think so!
OconeeOrange wrote:Good response.
I believe you are wrong - but no big deal. You have found what fits your ears.
At any rate, Sunfire perceived those as a failure, tried to improve with the 3s and so it goes.
I know people from the 60's with Sansui Speakers that will fight you if you say things have improved.
Like it or not - You will have Fun
I have too many 2's and no 3's and you dont have 2's!!!Return to Buy/Sell/Trade for Newbies
