Carver Platinum Mark IV
If you are new to the forum... (less than 50 post member) you are welcome to list your For Sale items here. Members with 50+ posts, will automatically gain access to the larger Marketplace.
Re: Carver Platinum Mark IV
Post by Scarabeo » Fri Nov 28, 2008 6:50 pm
It sounds like I should Bypass the internal Xover go with a DBX and have Ribbons take 200hz and up and the subs take 200hz and below and then use one of the 1.5t amps for the L/R Ribbons and the other 1.5t amp for the L/R Sub's,,,Is this correct? If so pretty easy so far! I do plan on re-wiring the Subs with thicker cable so I may just cut and bypass the subs at that point. Thanks everyone and if I am wrong here jump in and yell at me...
Post by BillD » Fri Nov 28, 2008 8:36 pm
What I'd do is leave the ribbon crossover in so it can take care of the ribbon non-linearities, but disconnect the subs and run them direct up to the 200Hz cross point (the internal crossover I believe crosses below that, and you don't want a hole in your response curve). Then use the electronic crossover to cross at any frequency you desire ABOVE the internal ribbon crossover point.
spl
Post by spl » Sun Nov 30, 2008 12:39 pm
I believe Clearview was bought over by Audio-X-Stream which I believe is now defunct which was started by a gentleman named Rudi Blondia.
Here is a link to some info on these crossovers:
http://www.audioxstream.com/cxrframe.html
Anybody interested may want to see if they can hunt one down in the used market. Currently, the Carver ribbons and woofers are good, not great, in my opinion. This is compared to what is available TODAY. Back when they were first introduced, they were the speakers to beat for their price. However, other loudspeaker companies who make much more refined and robust versions, but they are obscenely expensive.
There is now doubt that to get the best from a "Carver" style loudspeaker you must do the following:
1. Separate baffles (or enclosures) for the ribbons and the woofers
2. External active DSP crossover
3. A large enough room to let them really get down and boogie
This gives you infinite ability to fine tune the speakers to your personal tastes - different preamps, amps, toe in, tilt, etc.
Just my 2 cents...
Brucest
Carver Platinum MK IV for sale
Post by Brucest » Wed Feb 11, 2009 6:12 pm
Biamped, Behringer Xover, extra ribbon, new woofers. $1500.
ViperZ
Re: Carver Platinum MK IV for sale
Post by ViperZ » Wed Feb 11, 2009 6:56 pm
And your location is? =D>
Post by F1nut » Wed Feb 11, 2009 8:39 pm
Post by Toy Maker » Wed Feb 11, 2009 9:09 pm
Bi-amping your speakers IS a good thing !!! BUT, I am pretty sure you have messed up the equalization in doing so.
Almost ALL speakers have internal "passive" equalization in them. By removing the crossovers all together, you have also "de-tuned" them.
I know, because I did the same thing myself. And it took Bob Carver about 5 hours to re-tune them using a 31 band EQ.
There are notch filters for the ribbons around 6000-7000 Hz, and some other stuff going on in there.
The clearview crossover DOES compensate for the EQ. It is a 2-way crossover AND an active EQ to re-tune the drivers.
I have one, and I am using it, but it's on its way to Tom pretty soon.
Here's Bob tweakin' away !!! 8) As you can see the EQ on top, is anything but flat.
Post by TNRabbit » Wed Feb 11, 2009 9:17 pm
Hmm...why the new thread, Brucest?
Return to “Buy/Sell/Trade for Newbies”
