remote for htr-880
If you are new to the forum... (less than 50 post member) you are welcome to list your For Sale items here. Members with 50+ posts, will automatically gain access to the larger Marketplace.
cutlass81
remote for htr-880
Post by cutlass81 » Sun Feb 15, 2009 2:49 am
Hello forum. I recently picked up a HTR-880, but am remoteless. Can anyone help me locate this remote?????? I believe it is the RH-88. Any help would be greatly apprecitated. Thanx. BTW...been reading around the forum a bit, lots of info here...very helpfull.
Re: remote for htr-880
Post by OBI56 » Sun Feb 15, 2009 3:50 am
Hello Cutlass. That remote is no longer available but this place has used ones and substitute ones in stock.
https://secure.remotes.com/remotes/serv ... ARVER_RH88
cutlass81
Post by cutlass81 » Sun Feb 15, 2009 4:28 pm
Thank you very much OBI56, I placed an order for the "lightly scratched" one. I was searching around for a few hours last nite looking for the remote and any other kind of info on this piece of gear. Is it just me, or is this receiver kind of obscure? As I couldn't find much on the User Manual either. Found this forum tho, and happy for that. Thanx again.
Post by OBI56 » Sun Feb 15, 2009 6:30 pm
Here is all the information I have on it Cutlass.
Gold Plated RCA Jack Connections, Remote Control, Exclusive Power Steering circuitry provides over 50% more power on demand for selected amplifier channels, Phono Input Stage, Two AC outlets one switched and one unswitched, Removable handles for 17" cabinet space (with trim caps), Motor-driven Volume control can be operated from the remote control, Designed by Carver Corporation in Lynnwood, WA USA, Frequency Repsonse 20-20kHz +/- 0.5dB, S/N MM Phono A-Weighted > 75dB, Input Sensitivity for 0.5V 34mV, Input Impedance 47 kohms, Maximum Input Level 5.5V, Output Impedance 1 kohm, Maximum Output Level 7V Input, Sensitivity for 0.5V phono 3.5mV
cutlass81
Post by cutlass81 » Mon Feb 16, 2009 2:21 pm
Yup, OBI.... that's about what I found on info too. Got it hooked to the small Polk M30's right now and it sounds pretty good at all volumes. Later today I'll hook it up to my RTi 10's and see how it drives them.
Post by Toy Maker » Mon Feb 16, 2009 2:38 pm
I think Rolland might have some of those as well
gdb
Post by gdb » Mon Feb 16, 2009 2:43 pm
cutlass81
Post by cutlass81 » Thu Feb 19, 2009 3:02 pm
thanx tfm.....might have to go thru them...looks like they have one.
Return to “Buy/Sell/Trade for Newbies”
