Need rack handles for a CT-28V... please?
If you are new to the forum... (less than 50 post member) you are welcome to list your For Sale items here. Members with 50+ posts, will automatically gain access to the larger Marketplace.
LohnieM
Post by LohnieM » Fri Mar 06, 2009 10:53 am
Anyone have a set they'd be willing to part with? Is there a set from something else that fits close enough that I could use just for cosmetics?
Any help is appreciated!
Sincerely,
LohnieM
703.880.4859
Re: Need rack handles for a CT-28V... please?
Post by Toy Maker » Fri Mar 06, 2009 11:04 am
Can someone please post that website again, that sells the handles, I can't find it again ](*,)
Post by thuffman03 » Fri Mar 06, 2009 11:20 am
Post by BillD » Fri Mar 06, 2009 11:20 am
HERE
oops. two at once
Post by thuffman03 » Fri Mar 06, 2009 11:22 am
BillD wrote:HERE
oops. two at once
We are so eager to help!
Post by Toy Maker » Fri Mar 06, 2009 11:27 am
That's them. thanks guys !
Post by BillD » Fri Mar 06, 2009 11:45 am
Does anyone know the parts necessary to do M-500 rack handles? I'd love to have a pair for mine.
Post by OBI56 » Fri Mar 06, 2009 1:53 pm
BillD wrote:Does anyone know the parts necessary to do M-500 rack handles? I'd love to have a pair for mine.
Bill, the only item that is a bit of a problem are the removable rack ears as the handles and ferrules are available off the shelf from Lyntron. The rack ears should not be a problem to make as they are basically angle aluminium extrusions cut to length with the proper mounting holes drilled. Maybe someone has a set on an amp or spare set hanging around that someone could measure or duplicate for you. Might not be a bad idea to have a spare set or 2 made up while you are at it; always someone who wants a set of those on here.
LohnieM
Post by LohnieM » Sun Mar 08, 2009 11:55 am
Sorry, better clarify - the actual handles are fine, it's the aluminum "ears" that are all beat up.
Any ideas?
Post by OBI56 » Sun Mar 08, 2009 1:40 pm
LohnieM wrote:Sorry, better clarify - the actual handles are fine, it's the aluminum "ears" that are all beat up.
Any ideas?
I've never seen a CT-28v up close and hadn't realized that it also uses ears, so the same thing applies as for the M-500 series ears. Are they bent out of shape or just scratched? If so, you can easily buff out most of the deeper cratches adn do some touch-ups with either a permanent felt marker on small scratches or by using something to hide scratches on guns which I have been told maytches up quite well and is available at any good gun shop
I seriously doubt that you are going to find a lot of those hanging around so you may wind up having to have some made up if your's are too far gone for simple re-finishing. I'm also thinking at the same ears that were used on many of the Carver CD players would also fit if the vertical casing size is the same.
ViperZ
Post by ViperZ » Fri Mar 13, 2009 6:23 pm
OBI, my CT-28v is rack-mountable :D , and I did post a picture of it ;).
Rainman
Post by Rainman » Sat Mar 14, 2009 1:53 am
Is it the removable part of the ears that are dinged up?
The reason I ask is if this is the case I can inquire with a friend at the shop who is one of the best chassis and body fabricators you will find anywhere. He also happens to be a metalurgical engineer so he can make ANYTHING out of metal. Since most of the cars are pretty much done he might be willing to "hack" a couple out. Matching the color could be the only hang up because I believe those are anodized which can be done at the shop. I will have to see if that color is available...
Having a couple extra parts for our 28v could come in handy at one point...
btw: have you ever seen someone tig weld the foil that comes inside a pack of cigarettes?
Rainman
Post by Magnaryder » Sat Mar 14, 2009 3:00 pm
Rainman wrote:Is it the removable part of the ears that are dinged up?
Rainman
watched 2 guys at USMarine tig gum wrappers about 20 years ago. They built the Winston Cup and TransAm cars Baja
Boats was running back in the day.
Rainman
Post by Rainman » Sun Mar 15, 2009 2:21 am
I was quite happy with myself being able to do pop cans... Until I was shown the cig. foil lap weld :shock: After that I suddenly lost the desire to go any further than pop cans..... Incidentally we also build the same stuff that your friends were building when they showed you the gum wrapper welding..
btw: You can not weld the gum wrappers or cig foil anymore because just like everything else these days, the cheap asses don't use real foil anymore!!!!
Rainman
Post by Magnaryder » Sun Mar 15, 2009 9:07 pm
Rainman wrote:I was quite happy with myself being able to do pop cans... Until I was shown the cig. foil lap weld :shock: After that I suddenly lost the desire to go any further than pop cans..... Incidentally we also build the same stuff that your friends were building when they showed you the gum wrapper welding..
Rainman
I noticed that the other day when one of my kids gave me a pice of gum. hell I thought it was just the boutique gum but NO it's all of 'em. SHIT what's happening to the world???
Return to “Buy/Sell/Trade for Newbies”
