It is currently Wed Jun 19, 2013 3:13 pm
Silver Seven's Capacitor change
Post Sun Apr 15, 2012 2:29 pm
My set of Silver Seven's developed a loud pop (really loud) when I turned the amp off.
Even with the the level control turned all the way down and the pre amp turned off.
As i did not want to damage my speakers, I had to get it taken care off ASAP. Quick phone call to Bob
Bob gave me a couple of things to check out, one of them was a couple of caps that ground out the 660vdc B+ line.
So after checking them i found one was weak, time to change the caps. There are 3 of these caps in each amp so I ordered
6 x Jensen Audio Grade 47uf 450vdc caps. ( originals where Mallory (date code Sept 1989) 50uf 450vdc)
Chris at Parts Connexion told me the slight difference in values would not matter.
Due to the large size of the case, it turned out to be a very easy job, 30 mins per mono block.
After a quick test, all works fine. No pop's now \:D/ \:D/ \:D/
Inside a Silver Seven
Old Caps
New Caps
Pair all done
Right Hand Cap installed
Splice, as leads not long enough
Testing the amp
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
Post Sun Apr 15, 2012 3:04 pm
Re: Silver Seven's Capacitor change
Nice work Brian!!! =D>
Post Sun Apr 15, 2012 3:27 pm
Congrats on a great job.
Post Sun Apr 15, 2012 3:51 pm
Nice caps and nice work there Brian. =D>
Martin1970
Post Sun Apr 15, 2012 4:33 pm
Perfect work, as per your norm.
Did you find yourself saying, "Holy crap! I'm replacing parts in a Silver Seven."
I'd have been nervous as hell.
Rane: RPM88 26Z x3
Post Sun Apr 15, 2012 4:47 pm
Martin1970 wrote:Perfect work, as per your norm.
Ditto here Martin....my hands would have been shaking too much to do it.. :lol:
Post Sun Apr 15, 2012 5:51 pm
Martin1970 wrote:Did you find yourself saying, "Holy crap! I'm replacing parts in a Silver Seven."
Martin
No I was not nervous, it was a lot easier working inside them than working on the Carverfest Amp's
Due to there age, I think I will be replacing a few more cap's over the next few years.
Thanks for the positive comments on my work.
Carver TX11.
B&W 802D's Rosenut
Post Sun Apr 15, 2012 7:12 pm
nice job....
glad you got it working.
Post Sun Apr 15, 2012 11:12 pm
Nice work Brian, if you need somebody to sound check those amps just send them on down :-" :-"
Lightstar serial #0008
400x7
300x2
SD/A 490t
Sunfire Tube preamp
ProJect TT Tube preamp
JL Audio 12W7's
Post Mon Apr 16, 2012 11:55 am
Nice job Brian!
Post Fri Apr 20, 2012 8:17 pm
Very nice work, can't wait to see pics with the new tubes in
Return to Carver Tubes
