It is currently Wed May 22, 2013 3:20 pm
This one for you James! Check this out!
Post Tue Nov 27, 2012 9:59 pm
Post Wed Nov 28, 2012 4:31 pm
Re: This one for you James! Check this out!
What does a Transporter do? Not "beam me up, Scottie", I assume....
The eBay ad was of little help in answering....
Post Wed Nov 28, 2012 6:29 pm
elgrau wrote:What does a Transporter do? Not "beam me up, Scottie", I assume....
Its similar to a Squeezebox touch but I believe it has a built in hard drive and more options. So its like the Squeezebox Touch + NAS
It was their top of the line offering above the Squeezebox. Might do higher res file types too.....
More info here: http://www.logitech.com/en-us/special-o ... sporter-se
Post Wed Nov 28, 2012 6:50 pm
Stock ones were originally @$2000.00.....
