This one for you James! Check this out!
Post by Eddie » Tue Nov 27, 2012 8:59 pm
Re: This one for you James! Check this out!
Post by elgrau » Wed Nov 28, 2012 3:31 pm
What does a Transporter do? Not "beam me up, Scottie", I assume....
The eBay ad was of little help in answering....
EndersShadow
Post by EndersShadow » Wed Nov 28, 2012 5:29 pm
elgrau wrote:What does a Transporter do? Not "beam me up, Scottie", I assume....
Its similar to a Squeezebox touch but I believe it has a built in hard drive and more options. So its like the Squeezebox Touch + NAS
It was their top of the line offering above the Squeezebox. Might do higher res file types too.....
More info here: http://www.logitech.com/en-us/special-o ... sporter-se
Post by TNRabbit » Wed Nov 28, 2012 5:50 pm
Stock ones were originally @$2000.00.....
Return to “Carver Tubes”
