It is currently Tue May 21, 2013 10:52 am
Silver-7 restoration / update
Post Mon Dec 03, 2012 2:41 pm
We are beginning to completely restore and upgrade a pair of Silver-7 tube amplifiers.
Something we haven't seen anyone else attempt before.
We'll be refinishing the chassis in high gloss black powder coating. The original lacquer finish was nice, but not durable what so ever. This new finish will last the life of the amplifiers. We will also be updating the RCA and binding connectors, and adding an IEC. also adding amber LEDs to the meters to match the Silver-1 preamp design.
http://www.facebook.com/groups/94906064 ... tif_t=like
Post Mon Dec 03, 2012 2:55 pm
Re: Silver-7 restoration / update
Cool project, TM...Good Luck!
Post Mon Dec 03, 2012 3:26 pm
Right on!! =D> =D> These aren't the "New" ones that were just on eBay are they? :-k :-k
Post Mon Dec 03, 2012 4:06 pm
No. This is a set my father put in storage a couple years ago, after getting the original Silver-7 prototypes from Bobs personal collection.
Post Mon Dec 03, 2012 5:50 pm
Very cool project. I will be looking forward to reading about the updates and pic's.
Post Mon Dec 03, 2012 7:13 pm
James.
Thats real funny that you have started this restoration on the Silver Sevens.
I have just finished upgrading all the caps in one amp and DC restorer circuit , have not had time to do the other.
When I am finished the other amp, I was planing on adding an IEC.
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
Post Mon Dec 03, 2012 7:30 pm
VERY nice. How much do you have into the upgraded parts so far?
Post Mon Dec 03, 2012 7:39 pm
Damn, Duelund and Jensen Caps!!! Holy Shit. You've got to tell us about the difference in sound. Did you change any of the resistors?
Post Mon Dec 03, 2012 8:30 pm
Toy Maker wrote:VERY nice. How much do you have into the upgraded parts so far?
James.
I am real busy tonight, will give you a break down on cost tomorrow.
Carver TX11.
B&W 802D's Rosenut
Post Tue Dec 04, 2012 7:07 pm
James.
Here is a list of the cap's Etc, we are looking at about $800.00 per amp chassis plus taxes.
2 x Duelund 76340 PIO 0.47uf $199.99ea
4 x ALEX-75267 0.01uf $ 40.61ea
2 x ALEX-75179 1.0uf $ 93.71ea
1 x OBLIG-74473 0.22uf $ 28.00ea
1 x CLARITY-74839 0.25uf $ 10.01ea
3 x JENSEN-73343 47uf $ 15.41ea
2 x Diodes
6ft Silver Wire
1 x 3K Resistor
1 x 68K Resistor
Wire insulation
Hows your restoration going?
Carver TX11.
B&W 802D's Rosenut
Post Wed Dec 05, 2012 3:40 am
You're not suppose to toss them around like ya'll do.
Post Wed Dec 05, 2012 3:43 am
Brian, nice work. I am curious tho, why all the different brands of caps?
Post Wed Dec 05, 2012 7:51 am
F1nut wrote:Brian, nice work. I am curious tho, why all the different brands of caps?
Jessie.
Me not knowing the sonic difference, in in brands of caps I sent Chris Johnson @ partsconection (formally Sonic Frontiers)
the wiring schematic to have a look at.
The caps I used are what he chose, I did not question the the different brands, The ALEX are made by Duelund
Carver TX11.
B&W 802D's Rosenut
Post Wed Dec 05, 2012 3:44 pm
Excellent work Brian! You're a better man than me!!!! =D> =D> =D>
Post Wed Dec 05, 2012 7:07 pm
BrianT wrote: Jesse.
Got it, thanks.
What I see are some bypass caps that were originally used to help out the crappy stock electrolytic and mylar caps. Since you are upgrading those, there really is no need to use bypass caps now. I've found that bypassing high quality film/foil caps results in unwanted artifacts. Also, not using bypass caps now will save you money.
One I don't really get is the OBLIG-74473 0.22uf (gold one), CLARITY-74839 0.25uf (silver one)and the ALEX-75267 0.01uf (black one, is that an ALEX) all together. Three different caps, three different flavors when all that is needed is one high quality 0.48uF cap.
