It is currently Fri May 24, 2013 8:02 pm
What gear are you bringing?
i will bring a sonic frontier sfl-1 hybrid preamp. a tfm55 that has been in constant use since new. another tfm 55 that roland is refreshing if i get it back in time. also may bring a tfm 35 to hear if the japan made model has a different tone to it than the us made ones.
Re: What gear are you bringing?
angelod307 wrote:i will bring a sonic frontier sfl-1 hybrid preamp. a tfm55 that has been in constant use since new. another tfm 55 that roland is refreshing if i get it back in time. also may bring a tfm 35 to hear if the japan made model has a different tone to it than the us made ones.
thuffman03 wrote:I know what I will be bringing.
ALIII
2 Sunfire 300
2 Sunfire True sub
Sunfire TGP
TFM 55
C-19
C-9
SDA 490t
I have a good idea what beemers417 and BrianT will bring down but I will let them respond.
I have since acquired an SD/A 390t that will be joining my other equipment at CF this year. I don't think we can fit my Plats with everything else we are taking so they are going to stay home.
Just bringing some amps for Bob to sign.
(2) TFM-55's
TFM-45, refurbished recently by Rolland (son Matt's birthday present)
806
Members are welcome to compare any of my amps with any of theirs.
Just let me know. Checking in the 16th through the 19th.
(2) TFM-55's
806
Just let me know. Checking in the 16th through the 19th.(pair of) SILVER-7 TUBE AMPs
I'm thinking........................................
Don wrote:Just bringing some amps for Bob to sign. TFM-75
treitz3 wrote:Oh dear....does it work? We have never had one at a 'Fest before and many folks [myself included] would like to hear one.Don wrote:Just bringing some amps for Bob to sign. TFM-75
Tom,
Yes, the TFM-75 works like a charm, as well as the other amps I am bringing.
Currently in my system powering my Plat.#4.
Bought it new when I bought the Plat's. Original owner of both.
You or any other forum member is welcome to plug it into their system for comparision or any other amp for that matter.Re: What gear are you bringing?
thuffman03 wrote:thuffman03 wrote:I know what I will be bringing.
ALIII
2 Sunfire 300
2 Sunfire True sub
Sunfire TGP
TFM 55
C-19
C-9
SDA 490t
I don't think there will be any room left after Tom's list.
I will try to cram In:
VMPS Supertower II/R's Nice bookshelf speakers
Sunfire Tube Pre
C-6
TX-12 ( might be special)
TL-3300
DTL-200 MK II
beemers417 wrote:thuffman03 wrote:thuffman03 wrote:I know what I will be bringing.
ALIII
2 Sunfire 300
2 Sunfire True sub
Sunfire TGP
TFM 55
C-19
C-9
SDA 490t
I don't think there will be any room left after Tom's list.![]()
VMPS Supertower II/R's Nice bookshelf speakers![]()
Sunfire Tube Pre
C-6
TX-12 ( might be special)![]()
TL-3300
DTL-200 MK II
Tom.
Does the Sunfire Tube Pre have the phono option, if so I might need to borrow it as I have not got mine back from Bob yet.
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
Carver TX11.
B&W 802D's Rosenut
Brian,
The one Tom has does not have the Phono stage. I will have my C-19 and it's phono stage should work fine with your table IMO. Though I do think Tom has an external phono stage that he can use on the Sunfire.
thuffman03 wrote:Brian,
Thanks Tom.
Beemers sent me a PM saying that, one way ore the othe we will work it out.
I do think that the C-19 will work perfect.
Are you and Beemers in for Pat's Turkey Supper?
Brian.
Carver TX11.
B&W 802D's Rosenut
Carver TX11.
B&W 802D's Rosenut
hello all. so, i am disappointed that the sonic frontier sfl-1 preamp has a channel imbalance since i have put it away a few years back. what are the odds of oh, i don't know, having a repair workshop....ok, i may be stretching it there. just do not know what went wrong. one side plays a bit louder than the other. it only uses one tube if my memory serves me correct with out opening the top. any thought's as sonic frontier is not at the forefront as a company and i see that the founder/ceo/president is now doing mod work at the upgrade company i think.
Chris Johnson runs Parts ConneXion, http://www.partsconnexion.com and still services Sonic Frontier gear.
If that unit runs a single tube, it has to be a dual triode and as such you probably have a bad triode section. Get a new tube before doing anything else.
Looks like more than one tube. Probably 6 triodes.
doh, that not the one. sfl-1. like the one in the link below.
http://archive.anthemav.com/OldSitev1//pdf/sfl1.pdf
