It is currently Sat May 25, 2013 11:42 am
Anaconda Speaker Cables
Post Tue Jul 27, 2010 3:51 am
Re: Anaconda Speaker Cables
that looks alot like rockford fosgate power wire. anyway, i used some 8 gauge rockford wire myself to run my h/t setup. works flawlessly. 4 gauge is over kill for me. 250' i used would really make my wallet light at checkout. 500' total 8g, 250 red and 250 black was about $450. considering the awesome wires within the AL-III's that i own (wow, what an understatement right), the 8g wire seemed to be more than enough....
ekog
Post Sun Jul 17, 2011 7:08 pm
Toy Maker wrote:Finally !!!! got the custom designed 8ga speaker cable connectors in.
These match the RCA's perfectly =D>
These look much better made the ones you got from China but as these are different how will the nylon braiding finish up to the end of the cable now (will the lug slide up over the nylon braiding and connect to the soldered connection on the cable side)? Looking at the connectors in the picture it appears that the Lug is screwed on to the soldered connection but the part it screws onto looks to be plastic with the weight you indicated in your original post this may be an issue (heavy cable will cause a lot of strain on the connectors themselves I can see strain relief being a consideration when connecting them up)
Main System Setup:
Second System Setup:
Post Sun Jul 17, 2011 10:29 pm
Nope, no problems there... The white nylon is a bushing to keep the outer bodies isolated, so if the 2 bodies touch each other, you are not grounding your amp.
The outer body is really only cosmetic.
Post Sun Jul 17, 2011 11:00 pm
Did you ever decide on a price for these, James?
Post Sun Jul 17, 2011 11:30 pm
No... The project got put on hold. The materials cost up front was pretty high.
We have a few other projects that are ahead of the speaker cables right now.
I never really sat down to do the math, but I think I figured about $250 for a stereo set of 8' cables.
