It is currently Thu May 23, 2013 5:11 pm
CARVERaudio.com Interconnects
Post Sun Jan 31, 2010 9:14 pm
CARVERaudio.com / Directional Interconnect Cables
Constructed from extremely high quality components (Form & Function)
Pricing:
1.0 meter Pairs $99.00
2.0 Meter Pairs $169.00
Prices do not include shipping
Features:
Directional Cables: These Cables are Grounded At The Source, to insure induced noise, does not travel with the music signal
Core Wire:
Ultra-Flex 20AWG x2 OFC with 95% OFC braid filaments to insure least signal attenuation
Triple Insulation:
OFC braiding, cotton core wrapped CPVC to isolate any crosstalk and interference
RCA Connector:
Locking, Rhodium plated machined solid brass bodies, center pin, and collar
Termination:
High Quality Lead-free Solder. Tin alloy with 4% Silver, 0.5% Copper
Exterior:
Military-Grade Super-Flex Ultra-Soft "cloth-like" braiding (nothing like the rigid plastic Nylon braid you usually see on cables)
Details:
Why use directional Interconnects??
In cables where the shield does not carry the signal or ground, the shield is normally only connected to ground at one end. In systems where there are significant differences between ground levels on various components, it may make a difference which way such cables are connected. Typically, the end where the shield is grounded should be at the source of the signal. Often, such cable has arrows on it pointing in the direction of the signal flow.
In Single-Ended interconnects, the signal wire and the ground wire (or shield in the case of coaxial construction) form a complete circuit, so both conductors carry signal currents. The ground wire or shield also serves the purpose of bringing the potential of the two components to the same level.
Why use Rhodium?
Rhodium (pronounced /ˈroʊdiəm/ ROH-dee-əm) is a rare, hard transition metal and a member of the platinum group, that does not normally form an oxide, even when heated. Oxygen is absorbed from the atmosphere at the melting point of rhodium, but on solidification, the oxygen is released. Rhodium has both a higher melting point and lower density than platinum. It is not attacked by acids.
Loop Resistance (Ohm/m) 0.005
Parallel Capacitance (pF/m) 49.1
Loop Inductance (per/m) 0.15
Dissipation Factor (@10Khz) 0.0008
Overall Size (mm) 9.3mm Φ
Post Mon Feb 01, 2010 9:05 am
Re: CARVERaudio.com Interconnects
Perty. I'll take 4 (2 pair) at 18 inches each. Thx~
Post Mon Feb 01, 2010 1:38 pm
I don't plan to make the 1/2 meter pairs... (too short)
I do still have 3-4 sets, ( non-directional) but after them, I think I am going to stick with the 1-meter lengths and above.
Gary. If you'd like the short, "non-directional" ones I have... I'll give them to you for $65 per pair.
If not, you'll have to go with the 1-meter "directional" cables...
I have both in stock, and can ship them tomorrow.
Post Mon Feb 01, 2010 2:01 pm
What's the differences between the short non-direction & directions models?
Post Mon Feb 01, 2010 2:29 pm
TNRabbit wrote:What's the differences between the short non-direction & directions models?
Gary, I think this means, IIRC, that the ground (shield) is connected at both ends. In the directional ones, you connect it only at the source end, so your components keep their own grounds and don't "share" the noise from another components ground. It is what most ground "lift" switches do inside the box which allows the box to float its ground separately from other components. It's typically no big deal, as most cables are grounded at both ends. So, if you aren't having trouble now, you won't with directionless cables.
Post Mon Feb 01, 2010 3:19 pm
Thank you Bill... well put !
Post Mon Feb 01, 2010 3:33 pm
Damn, just bought some WireWorld before I saw this.
This will sound kinda silly, but what about 1/4 inch (headphone type plug) to two RCA? I need at least five.
Post Mon Feb 01, 2010 5:57 pm
Toy Maker wrote:CARVERaudio.com / Directional Interconnect Cables
Pricing:
1.0 meter Pairs $96.00
1.5 meter Pairs $123.00
James,
You can put me down for:
2 x 1.0 meter pairs
1 x 1.5 meter pair
No RUSH, as I have to finish the KT88z upgrade 1st.
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
Post Mon Feb 01, 2010 6:03 pm
I got ya'
I have the tubes IN HAND, and going to box them now.
I will send the (2) 1-meter pairs with the tubes...
The 1.5 meter I have to make.
I'll put them on your tab =D>
Post Mon Feb 01, 2010 6:35 pm
That's very nice of you James, :)
Carver TX11.
B&W 802D's Rosenut
Post Mon Feb 01, 2010 7:00 pm
I would love to try these... can you put a pair of 2 meter and a set of one meter on my tab as well? [-o< :lol:
John
Post Mon Feb 01, 2010 9:24 pm
Hey yeah, good question? I don't have a tab now, but if I started a TAB or you created a tab, how much could I put on my TAB? :lol: :lol: :-k
Post Mon Feb 01, 2010 9:32 pm
damn good question as you might have posted that to rip us off.
Still, if you will bring those cables I need to Carverfest, I will throw in a bottle of good Scotch as a bonus.
Bill
Post Mon Feb 01, 2010 10:31 pm
=; [-X I don't drink... just bring me cash
Post Mon Feb 01, 2010 10:33 pm
nooshinjohn wrote:I would love to try these... can you put a pair of 2 meter and a set of one meter on my tab as well? [-o< :lol:
John
YOUR bill is racking up FAST.... You better start sending $$$ now :lol:
Still need to know what you are going to do ?? You keep changing your mind :lol:
