It is currently Tue May 21, 2013 12:42 pm
New member has problem with single al-III speaker
utmo
Post Mon Sep 07, 2009 10:22 pm
Hello all, new member here. Recently purchased a pair of oak al-iii after a long time looking. After a very long wait I found some and they worked well for about 3 months. Then all of a sudden I realized that one side would play much much lower than the other. I tried changing the amp connections, the wiring and settings on the back on the speakers but to no avail.
The speaker plays music, albeit at a very low level, and I want to see how to fix this.
Any help is much appreciated.
Thanks
Post Mon Sep 07, 2009 10:40 pm
Re: New member has problem with single al-III speaker
Sounds like your ribbon quit working, put your ear right to the ribbon and see if there is sound comming from it. Or just call me 315 893 7838, but do it in the next 2 days because I`M GOING TO CARVERFEST `09!!!!!!!!!!!!!!!!!!!!!!!
stevewithrow
Post Tue Sep 08, 2009 12:19 am
DaveS wrote:Sounds like your ribbon quit working, put your ear right to the ribbon and see if there is sound comming from it.
Dave is the man on this , Dave could be maybe the cross over since there is sound coming from it ?
csh72
Post Tue Sep 08, 2009 3:22 am
Someone on the forum has mentioned when their pots on a speaker went bad it was 6db lower than the other.If nothing is coming out of the ribbon check speaker connections,gold-plated binding post connectors,and even the fuse.Good luck.
utmo
Post Wed Sep 09, 2009 6:07 pm
There is sound coming from it, albeit at a very low level. It increases if I increase the overall volume but it is significantly lower than the other speaker.
I have checked the fuses and speaker wire connections. I opened up the back of the speaker to look/smell for anything burned but saw nothing.
I read the other members post about a similar problem but it was a different speaker type and I dont know where I should check resistance or what values to look for.
Thanks
Post Wed Sep 09, 2009 7:53 pm
Do this at lower volumes with a lower amount of bass to test it...
BYPASS the crossover. Connect the speaker wires directly to the leads at the bottom of the ribbon. This will tell you if it's the ribbon or not.
If it plays at louder volumes, you will know the ribbon is working fine, and its probably a crossover problem.
If you still get very low volumes from the ribbon by itself, you will know the problem IS the ribbon.
utmo
Post Thu Sep 10, 2009 4:22 pm
Toy Maker wrote:Do this at lower volumes with a lower amount of bass to test it...
thanks for the suggestion. I tried connecting it directly and still got the low volumes... what is next?
madmike46
Post Fri Sep 11, 2009 10:35 pm
DaveS wrote:Sounds like your ribbon quit working, put your ear right to the ribbon and see if there is sound comming from it. Or just call me 315 893 7838, but do it in the next 2 days because I`M GOING TO CARVERFEST `09!!!!!!!!!!!!!!!!!!!!!!!
Then I would call DaveS, I hear he is an expert in ribbons.
Post Sat Sep 12, 2009 6:12 am
WHERE ARE YOU ! If you are close to NC you may want to take a ride to CF9 and get it fixed! Ribbons do not ship very well and can get damaged in shipping if they are not packed very well! I would tell you to go out and buy a gun case the ones that are plastic and have the foam insides put into the case and have that case boxed and layered with extra padding !!!!!! Then ask Dave where to ship it! Eddie!
utmo
Post Mon Sep 14, 2009 2:43 am
unfortunately i am nowhere near NC. im in texas, san antonio.
i guess i need to get a hold of dave and see how to purchase a new ribbon then because it seems that my ribbon is gone :(
Post Sun Sep 20, 2009 11:36 pm
You can bet on it. I had the same problem with one of mine. Call Dave. I did.
stereo_buff
Post Mon Sep 21, 2009 8:38 am
utmo wrote:unfortunately i am nowhere near NC. im in texas, san antonio.
You may be able to get your existing ribbon repaired, instead of buying a new one - see what DaveS says...
utmo
Post Fri Nov 20, 2009 5:22 pm
I know its been forever since I wrote back on here but school got kinda crazy. Anyways, I wanted to see if it was still ok to call you at that number Dave because its been busy and acting funny all day?
