It is currently Sat May 18, 2013 1:28 pm
al111 and amps
2-tall
Post Thu Oct 29, 2009 11:39 pm
al111 and amps
I have 2 tfm 24's and 1 tfm 35.Should i run the 2 24.s bi amped ( which are vertically bi amped now) or run the 35 to the ribbons and a 24 to the low end.If I go with the last idea will I have a problem with controlling volume levels because of two different amps.
Thanks
Post Fri Oct 30, 2009 12:00 am
Re: al111 and amps
I would say run the two 24's.
stevewithrow
Post Fri Oct 30, 2009 11:18 pm
Re: al111 and amps
thuffman03 wrote:I would say run the two 24's.
Or maybe the 35 to the ribbons and bridge each 24 to each woofer...
Post Fri Oct 30, 2009 11:47 pm
Re: al111 and amps
Not sure but is the woofers not 4 ohm?
2-tall
Post Sat Oct 31, 2009 10:30 am
Re: al111 and amps
Right if the woofers are 4 ohm then you can't bridge the 24's
audioassassin77
Post Wed Nov 11, 2009 12:06 am
Re: al111 and amps
the ribbons need far more power than the woofer section in the ALIIIs.
run the -35 stereo and try one -24 per woofer.
ALIIIs are 6R nominal...cant recall exact resistance on woofer section and my meter is at work....if i remember ill bring it home and check tomorrow.
or..just keep an eye on the meters/ temp. and you should be fine.
Post Wed Nov 11, 2009 9:40 pm
Re: al111 and amps
audioassassin77 wrote:the ribbons need far more power than the woofer section in the ALIIIs.
The AL-IIIs are a HARD 4-ohm load....ribbons more difficult than the woofers...
Post Wed Nov 11, 2009 10:50 pm
Re: al111 and amps
Ribbons are 4 Ohms almost entirely resistive.
