al111 and amps
Thanks
It is currently Thu May 23, 2013 4:36 am
thuffman03 wrote:I would say run the two 24's.
stevewithrow wrote:thuffman03 wrote:I would say run the two 24's.
Or maybe the 35 to the ribbons and bridge each 24 to each woofer...
audioassassin77 wrote:the ribbons need far more power than the woofer section in the ALIIIs.
run the -35 stereo and try one -24 per woofer.
ALIIIs are 6R nominal...cant recall exact resistance on woofer section and my meter is at work....if i remember ill bring it home and check tomorrow.
or..just keep an eye on the meters/ temp. and you should be fine.
