nice...
the ribbons in these thing are nice and tight.
these were made in 95, so I would guess some of the last out the door.
the lady who owned them was the purchaser for carver,
said when they got down to 12 people left it was time to look for a new job.....
they used these as surround speakers, so my guess is these have low hours and were not drivven that hard, I think the woofer died due to the spider drying out,glue breaking away, and letting the V/C rub and smoke it self.
the bass level is way more than the oem thats for sure.....
I have the gains turned on the amps less than 1/2 up and it has a lot of punch......
the ribbons in these do look way different from the early ones, the alum strips are a lot flatter, less wrinkle if you will and they also have a small foam support in 3 places up the length of the ribbon, I would assume the back also.... kinda like a support to stop ribbon slap.
so on the silvers I have I did the hair dryer trick, this did help.
and I also used small felt strips about 3/8lgX1/2w 2 per spot, 3pl front and rear.
laid the speaker flat,
took a 10GA copper wire ground to a point to position them in place, then used silicone to stick them to the magnet,
then cut a strip of felt to cover the length of the ribbon down the back. used rubber cement, holds real good.
now I have no more ribbon slap on these ..........
I will add a 2nd set of binding posts to add a amp just for the woofers, not to sure about these rebuilt crossovers, just dont sound right down low...kinda muddy
and I think it lets too much low end to the ribbon,......
but all in all they sound okay, will play some more to make them sound great....
