It is currently Sat May 25, 2013 2:14 pm
Carver Amazings Origanals
Reese
Post Mon May 03, 2010 9:30 am
Re: Carver Amazings Origanals
Way to go!!!! A good trade (you probably have other guns around anyway....heheh)
These speakers are indeed AMAZING -- well named, for sure. Let me know if you need some coaching and advice on room placement. PM or otherwise. Agreed that they need some "space" behind and around them to really perform the best, and angled in a bit toward listening position can affect them in good ways for imaging. Buy your ears may be the best test of all, of course.
Reese
erniejade1
Post Mon May 03, 2010 10:18 am
Congrats!! I also have the original running on a Sunfire sig. 625 x 2. They do sound nice!!
Post Mon May 03, 2010 11:02 am
I'd go the active bi-amp of the woofers and the ribbons. Just disconnect the wires that go from the crossover to the woofer bank and wire new binding posts directly to the woofers. Set your crossover around 100Hz (actually, wherever it sounds best with Amazings.
Amazing Crossover.jpg (173.65 KiB) Viewed 153 times
Even though the wooofer equivalent resistance (Re) is 2.7Ω, the raw woofers are wired at 4Ω (sans crossover components).
stevewithrow
Post Mon May 03, 2010 11:08 am
Congrats on the ALS,s..I wouldn't up grade em , if you want silvers , go buy silvers , I have a set of originals my self , I use a Sunfire 300-2 for power....They sound incredible...I know the up grade REALLY help as far as sound and power requirements , but for me I wanted the originals , the 1st speaker EVER of its kind , and its a Carver....I will pick up some silvers some day , but I am also a collector of all carver , so why would I ever want to change em...But , thats just me....Enjoy those Originals and enjoy Bob,s work... =D>
damonrink
Post Mon May 03, 2010 4:34 pm
Thanks for the great advice!! One thing i do want to comment on, I have always used a real good EQ one that has a pink noise gen and the whole shibang. As soon as i started listening to ALS speakers, I kept adjusting it until it sounded the best and that was dead flat. So that is one piece i will not need. The Carver C-4000 pre has everything i need! :D
Post Tue May 04, 2010 4:49 am
What we're getting at is if you eventually actively biamp, you will have to reshape the eq as the internal crossovers (which help flatten the output) will be gone.
Post Tue May 04, 2010 11:11 am
But only on the ribbons.
erniejade1
Post Tue May 04, 2010 11:25 am
Re: Carver Amazings Originals
I am sorry to ask this on this tread but... On my ALS originals,, I find myself turning up the treble or on the bass unit ( the one for the ALS I cant recall the model number) I turn up the highs and keep the bass actually at -2... I do find the on flat a bit on the dark side. My question is if I do the bi amp trick, will that help brighten them up? Do I have to have 2 amps or with my Sig II 625X2, can I just run the voltage out and current out to the tops and bottom? Or will I not get the full benefit of doing a true bi amp?
I do have a Rance AC22b ( XLR only though so I would have to get a rca - xlr adapter) so a electronic crossover would be no problem.
Thanks and sorry to ask on this thread but, it is on the same subject...
Post Tue May 04, 2010 11:40 am
Need more details to give you a good recommendation, erniejade. Complete setup details, room size, pic if available...
erniejade1
Post Tue May 04, 2010 1:33 pm
Equipment,
Sunfire sig II 625 x 2 carver c19 pre Jolida cd100 cd. Technics 1200 with a Denon DL160 cart, From the Polk board ben's cables for IC's On the Sunfire I have it on the voltage out.. The current is just too much bass on the out.
Speakers are 3 feet from the corner, about 1 foot away from the wall. Cement basement! 26 X 24. The speakers are on the 24' side. I do have the amazings on carpet squares.
Next to them I do have a set of polk sda 1.2 running on the same as above except the amp is a McIntosh mc2105. ( I love that the c-19 has 2 sets of pre outs.
stevewithrow
Post Tue May 04, 2010 2:47 pm
erniejade1 wrote:Equipment,
I am sure Gary will chim in here..I also have the originals , I put a BBE sonic maximizer ( 422A ) Its a 2 channel...I have found my ALS,s to be on the flat side with out the 422a...I do not have a problem adjusting the treble ( +6 )OR bass ( +2 to 5 any less and they sound REAL flat ))to open up the ALS,s....I do not have the treble or bass flat on TGP////..I have found that my ASLS,s need to be pushed aggressively , if that makes sense...I like my stuff bright and boomy , with the mids in your face , so I will not have the treble and bass straight up and down..Like Bob always says " I dont know , lets try it...!! " oh , I have them connected to the voltage side of the amp...Current side made the ribbons sound real flat and skinney...When I Paradigm speakers , tone controls where straight up...Adjust tone controls to the + side , and take a listen...
erniejade1
Post Tue May 04, 2010 3:32 pm
I also have a bbe unit LOL i replaced it with the carver bass. Both do a great job actually. ( not with my polks just with the carvers) The polks because of the SDA the bbe is a huge no no. LOL
Post Tue May 04, 2010 4:21 pm
ernie, I started you a new thread so we don't pollute this one:
http://www.carveraudio.com/phpBB3/viewtopic.php?f=15&t=11763
Asoundpainter
Post Wed May 05, 2010 9:39 pm
Every post I read I get more interested in becoming more interested in Carver gear! I have 1.5t(2) driving VMPS Towers I've had since 1986. Built 'em from kit. Have gotten Silver's out from storage and am looking for replacement woofers for them. Job is slow so I have time to devote to the system. Any helpful suggestions would be appreciated. Thanks!
erniejade1
Post Thu May 06, 2010 1:33 pm
did the foam rot on the silvers?
There is a place that sells the woofers Let me look for the link.
BTW Witch VMPS towers did you build? I have heard some darn good sounding VMPS speakers!!
