To biamp or not to biamp; that is the question~
erniejade1 wrote:I am sorry to ask this on this tread but... On my ALS originals,, I find myself turning up the treble or on the bass unit ( the one for the ALS I cant recall the model number) I turn up the highs and keep the bass actually at -2... I do find the on flat a bit on the dark side. My question is if I do the bi amp trick, will that help brighten them up? Do I have to have 2 amps or with my Sig II 625X2, can I just run the voltage out and current out to the tops and bottom? Or will I not get the full benefit of doing a true bi amp?
I do have a Rance AC22b ( XLR only though so I would have to get a rca - xlr adapter) so a electronic crossover would be no problem.
Thanks and sorry to ask on this thread but, it is on the same subject...
Equipment,
Sunfire sig II 625 x 2 carver c19 pre Jolida cd100 cd. Technics 1200 with a Denon DL160 cart, From the Polk board ben's cables for IC's On the Sunfire I have it on the voltage out.. The current is just too much bass on the out.
Speakers are 3 feet from the corner, about 1 foot away from the wall. Cement basement! 26 X 24. The speakers are on the 24' side. I do have the amazings on carpet squares.
Next to them I do have a set of polk sda 1.2 running on the same as above except the amp is a McIntosh mc2105. ( I love that the c-19 has 2 sets of pre outs.
and here's Steve's reply:
I am sure Gary will chim in here..I also have the originals , I put a BBE sonic maximizer ( 422A ) Its a 2 channel...I have found my ALS,s to be on the flat side with out the 422a...I do not have a problem adjusting the treble ( +6 )OR bass ( +2 to 5 any less and they sound REAL flat ))to open up the ALS,s....I do not have the treble or bass flat on TGP////..I have found that my ASLS,s need to be pushed aggressively , if that makes sense...I like my stuff bright and boomy , with the mids in your face , so I will not have the treble and bass straight up and down..Like Bob always says " I dont know , lets try it...!! " oh , I have them connected to the voltage side of the amp...Current side made the ribbons sound real flat and skinney...When I Paradigm speakers , tone controls where straight up...Adjust tone controls to the + side , and take a listen...
So now we can start fresh & not pollute the other thread~
