It is currently Fri May 24, 2013 1:20 pm
Question on CRM-2's
mr3putt
Post Sat Nov 20, 2010 12:50 pm
Question on CRM-2's
Greetings
I am running a pair of CRM-2's with a Sunfire 300x2 amp fed from the AUX pre-out of a Sunfire Ultimate Receiver
The speaker manual says to set the bass crossover to 100hrz for the CRM's
Unfortunately the Ultimate pre-amp copies the signal from the Mains out to the AUX out.
My Mains are JBL L-100's and I would like to keep the low end frequencies to them.
Question:
If I continue to to send the full frequency range to the CRM's will I damage the speakers?
Thanks
Mr3putt
PS
The system sounds awesome \:D/
Sunfire Ultimate Reciever & Sunfire 300x2
Carver HR 895-TFM 15
Carver 490t CD
Carver 1770 Tape
Sunfire CRM-2's - 1 Pair
JBL-L100's
NHT Satellites-2 Pairs
Klipsch Sub
Technics SL-QD33 Turntable
Post Sat Nov 20, 2010 1:57 pm
Re: Question on CRM-2's
At low volumes it should be fine but if you plan on turning it up I'd unplug them. At higher levels running them full range it's pretty easy to drive them to distortion, which you might not be able to hear over your other speakers, and prolonged distortion will most certainly damage them.
Post Sat Nov 20, 2010 2:02 pm
You might be able to pass the signal through your subwoofer, depending on the model you have, which should give you atleast a 80hz crossover point. Just an idea...
Post Sat Nov 20, 2010 2:37 pm
Well, if your mains are set to "large", you get the full spectrum to them (and the aux outputs). You could try some F-MODs on the AUX outputs.
mr3putt
Post Sat Nov 20, 2010 3:17 pm
BillD wrote:Well, if your mains are set to "large", you get the full spectrum to them (and the aux outputs). You could try some F-MODs on the AUX outputs.
Thanks BillD
That's perfect
They are on the way
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Sat Nov 20, 2010 4:07 pm
Those f-mods are pretty slick-- I've never heard of them before and very reasonably priced.
stereo_buff
Post Mon Nov 22, 2010 5:46 pm
Bob (and Sunfire) specifically recommends that you not run the CRM-2s full-range.
