It is currently Thu May 23, 2013 9:59 pm
Need pics of AL III crossovers The 3 pot ones
Post Fri Oct 08, 2010 4:11 pm
Need pics of AL III crossovers The 3 pot ones. either email them or post them here. I don't care if they are over sized or not.
Post Fri Oct 08, 2010 6:04 pm
Re: Need pics of ALS crossovers The 3 pot ones
You mean the Mk.IVs? Are you sure you don't mean AL-IIIs.
Post Fri Oct 08, 2010 7:39 pm
Re: Need pics of AL III crossovers The 3 pot ones
Your correct.
Post Fri Oct 08, 2010 7:56 pm
I'm correct about which question. There were two that are contradictory. Only one can be correct.
Post Fri Oct 08, 2010 10:37 pm
Too much caffeine again Roy ?? :-"
Post Fri Oct 08, 2010 10:52 pm
AL-III crossover.jpg (47.95 KiB) Viewed 707 times
Post Sat Oct 09, 2010 6:52 am
I was hoping the pic would show where the upper right coil wires go.
Post Sat Oct 09, 2010 7:05 am
send me an email for some closeups. angelod307 at msn dot com.
Post Tue Oct 12, 2010 6:06 pm
bump
Post Tue Oct 12, 2010 6:21 pm
Post Tue Oct 12, 2010 9:18 pm
Thanks Mike & Bill.
Post Tue Oct 12, 2010 11:28 pm
The electrolytics are the same except my AL-III Plus have a pair of 175µF caps in paralleln (= 350µF) rather than the 300µF on the low pass filter.
Post Wed Oct 13, 2010 5:17 am
What does the differences in the caps do to the frequecy crossover points?
Post Wed Oct 13, 2010 1:07 pm
More capacitance would shorten the wavelength which results in a higher frequency. For instance if 300µF gave 150Hz, 350µF would give 170Hz, everything else remaining constant.
Post Wed Oct 13, 2010 2:20 pm
Cool. Bill, could you direct me to a good book on crossovers and how companents effect the frequency. I have the technical troubleshooting ability but not audio background.
