Finally did it
skip
aka (Sasquach)
Re: Finally did it
Post by skip » Fri Oct 15, 2010 9:38 am
weitrhino wrote:Skip,
How many times have you popped caps in your Plats? Your opening post kinda leads me to believe this has been a problem for you. I know about the one time at the 2008 fest, but has this been an issue for you with stock rated and branded caps?
Twice. Both times at a Fest. It's always the 150uf100V cap that blows. Bob said to step up the voltage rating of the cap and the problem should end. The new caps are 400V, so I should have no worries. Well, at least no worries about caps, with the extra wattage the caps will pass I might start blowing woofers and ribbons next.
Sasquatch
Re: Finally did it
Post by F1nut » Fri Oct 15, 2010 6:47 pm
skip wrote: Hadn't planned to, didn't know they would degrade over time. Think I should while I'm in there? What would be a good brand to use? How about the induction coils? Those might be rather hard to find I imagine.
You should absolutely upgrade the resistors. It is not a matter of degradation, it's a matter of the crappy stock high watt inductive resistors. Upgrading them will result in a very noticeable improvement.
The schematic I have for the standard Plat's shows the following, per speaker:
(4) 18 ohm 25 watt
(1) 7 ohm 7 watt
(2) 36 ohm 10 watt
As I'm sure you know, there are many revisions, so check your crossovers before ordering anything.
Anyway, for the 18 ohm, 25 watt resistors you will need to replace them with Mills non-inductive 18 ohm, 50 watt resistors available here, http://www.partsconnexion.com/resistors_mills_mrc.html
For the 7 watt and 10 watt resistors, replace them with Mills non-inductive 12 watt resistors available here, http://www.partsconnexion.com/resistors ... mra12.html
For the 7 ohm, use the 6.8 ohm, 12 watt as it's close enough.
For the 36 ohm, use two 18 ohm, 12 watt in series.
The inductors you would most likely have to have custom made. Northcreek would be able to handle that. I don't remember if the stock coils are metal (iron, steel laminate, ferrite) core or air core. There are advantages and disavantages to both types. One advantage with air cores is they don't saturate, one disadvanatge is they have a higher impedance. One advantage with metal cores is a lower resistance resulting in improved bass response, but they will saturate easier and will lower the over all impedance of the speaker, which very well could be a problem for your amp(s).
I'm going to suggest that you leave the inductors alone, at least for now.
Re: Finally did it
Post by BillD » Fri Oct 15, 2010 6:51 pm
I think you will find that the metal core inductors are typically used only on the low pass filter for the bass (look like little transformers). All the ribbon shaping and high pass filter inductors are air core.
Re: Finally did it
Post by engtaz » Fri Oct 15, 2010 7:03 pm
Great stuff F1.
Re: Finally did it
Post by Jag_97470 » Fri Oct 15, 2010 10:04 pm
Yes that is some great information F1Nut and BillD! Don't you just love this forum, some very intelligent and knowledgeable people always seem to come through when you need answers. =D> Speaking of intelligent and knowledgeable people, has anyone seen Brock around lately? :lol: :lol: :lol: :lol: :lol: Now that was a good one!!! :lol: :lol: :lol: :lol:
Re: Finally did it
Post by F1nut » Fri Oct 15, 2010 10:07 pm
I was suppose to hear from Brock last night, but nothing. I think he's so far down the rabbit hole with his new tube amp that we may not see him for awhile....LOL
Re: Finally did it
Post by Jag_97470 » Fri Oct 15, 2010 10:12 pm
F1nut wrote:I was suppose to hear from Brock last night, but nothing. I think he's so far down the rabbit hole with his new tube amp that we may not see him for awhile....LOL
LOL! Or; I hate to say it, but we all heard about Carverfest and the Drunk Crazy Bitch. Maybe he is depressed from what he learned at the doctors office?? :lol:
Re: Finally did it
Post by mbskeam » Fri Oct 15, 2010 10:45 pm
Report this post
whaaaa!!!!!!!!!!!!!!!!
is HE pregnant........ :-" :-" :-" :-" :-" :-" :-" :lol: :lol: :lol: :lol: :lol: :lol:
Re: Finally did it
Post by Jag_97470 » Fri Oct 15, 2010 11:17 pm
Report this post
ROFLMAO!!!!!! :lol: :lol: :lol:
Re: Finally did it
Post by Don » Sat Oct 16, 2010 2:52 am
Jag_97470 wrote:
Report this post
Now that was funny. :lol: :lol: :lol:
skip
aka (Sasquach)
Re: Finally did it
Post by skip » Mon Oct 18, 2010 10:47 am
F1,
Thanks again for the excellent advise. Just to be sure this novice understands, for two x-overs I will need:
(8) 18R/MRC50
(8) 18R/MRA-12
(2) 6R8/ MRA-12
Is that correct? Not sure how I can fit all of these caps and resistors on the existing board, but I'll figure something out.
Sasquatch
Re: Finally did it
Post by TNRabbit » Mon Oct 18, 2010 10:50 am
Hell, make a NEW BOARD~
skip
aka (Sasquach)
Re: Finally did it
Post by skip » Mon Oct 18, 2010 2:07 pm
TNRabbit wrote:Hell, make a NEW BOARD~
That's what I'll do if I can get the inductor coils off of the old one without destroying them. Of course that would mean I would have to read the schematic rather than replacing one part at a time into it's old position which is risky for an electronics idiot like myself.
Sasquatch
Re: Finally did it
Post by F1nut » Mon Oct 18, 2010 8:23 pm
skip wrote:F1,
(8) 18R/MRC50
(8) 18R/MRA-12
(2) 6R8/ MRA-12
That's it.
skip
aka (Sasquach)
Re: Finally did it
Post by skip » Tue Oct 19, 2010 6:35 am
F1nut wrote:
skip wrote:F1,
(8) 18R/MRC50
(8) 18R/MRA-12
(2) 6R8/ MRA-12
That's it.
Thank you kind sir.
Sasquatch
Return to “Carver Speakers”
