Now What Should I Do
Beachbum
Post by Beachbum » Thu Apr 14, 2011 6:39 pm
Well In My OVER ANXIOUSNESS To Get A Second Set Of Carvers I Got A Really Raw Deal
First I Drive 300 Miles To find That They are Not The 5"3" Model They Are The Smaller Ones And Not In Great Shape But I Said To Myself i Just drove All This way and This was The second Time This Happened I Made The Deal
I Was Supposed To Get The Large Ones For $ 600.00 and I Could Only Get The Smaller Ones For $ 460.00 He Assured Me They Played Perfect.
Well As My Luck Has It ALL 6 Woofers Foam Suround MISSING/DAMAGED Using A Flaslight To Backlite The Ribbons They Look REAL Good.
Can The Woofers (if the voice coil is not damaged) Be REFOAMED
Is It Something I Can Do Myself ???????
If Not Can Someone Recommend A Place That Does It
If So Are The Kits Real Close To Orginal ?????
How Do I Tell if The Voice Coil Is Bad Without Driving Them If Refoaming Is Possible ????
If None Of The Above Is Possible Is There Still Only The One Supplier (that raised thier prices lol) That Carry Replacements
Is There a Way For Me To Tell If The Ribbons are Bad BEFORE I Invest In 6 Woofers ????
THANKS IN ADVANCE to All that can respond
Beachbum
ONCE YOU HEAR
F L A C
YOU WILL NEVER GO BACK (to mp3)
Re: Now What Should I Do
Post by frankieD » Thu Apr 14, 2011 7:10 pm
I don't know where you are but a shop in Ventura will re foam the woofers and can repair the vc if needed.
The bad news is the re foam is $45.00 so you might want to go with orovox woofers replacements.
As far as the speakers go, if the ribbons are good the Silvers (small ?) speakers with 3 woofers per side are great & unless you have an auditorium sized listening room they will (with enough power) blow your mind.
Good luck.
Beachbum
Post by Beachbum » Thu Apr 14, 2011 7:24 pm
Well I am Glad I Did not Try To Get My Real Name As The Screen Name Because FrankieD There Are Two Of Us Here WoW Talk About Coincidence
As Far As BLOW MY MIND I Did That Long Time Ago lol
My Goal Is To Have My Orginal Amazings As A ReaR Channel I Want To Get A Set Of Platinums For The Front Channel and Use The Set Of Silvers For The Side Channels ( I Know I Know I Lost my Mind )
ONCE YOU HEAR
F L A C
Post by BillD » Thu Apr 14, 2011 7:27 pm
There's this guy known as Ferrari :-"
Post by TNRabbit » Thu Apr 14, 2011 9:45 pm
FYI: the Silvers at 5' 3" ARE the small model; the Platinums & Originals are 6' tall.
yeah, Search on "Ferrari" & see what FIVE PAIR of Platinums looks like in a full 5.1 system~
Post by TNRabbit » Wed Apr 20, 2011 9:19 am
SO.....did you decide to order new woofers from Orevox?
Beachbum
Post by Beachbum » Wed Apr 20, 2011 8:48 pm
Ada said They are Out Of Stock : (
She Will E Mail Me When The Shipment Arrives
Man I Hope They Are The Same Specs !!!!
Well I Need All 6 So At Least They Will All be From The Same Run
ONCE YOU HEAR
F L A C
Post by mbskeam » Wed Apr 20, 2011 8:56 pm
I wish they would just order up some goddam surrounds and sell those also...... ](*,) ](*,) ](*,)
they have the maker right there, for shits sake ](*,) ](*,) ](*,)
Post by kingman » Wed Apr 20, 2011 9:43 pm
....NAW!!!!!...there can only be 1 FrankieD...YO FRANKIE!!!!! :lol: :lol: :lol:
Post by mbskeam » Wed Apr 20, 2011 9:51 pm
frankieD wrote:I don't know where you are but a shop in Ventura will re foam the woofers and can repair the vc if needed.
could you see what they use for the surround??????????
Beachbum
Post by Beachbum » Wed Apr 20, 2011 10:38 pm
I'll Post Pics As SOON As I GET THEM.
ONCE YOU HEAR
F L A C
Return to “Carver Speakers”
