It is currently Thu May 23, 2013 8:58 am
AL-lll+ audition
67ih4x4x4
Post Sat Jun 11, 2011 4:00 pm
AL-lll+ audition
I'm going to audition a pair of AL-lll+ tomorrow . Does anyone have any sugestions on anything I should be looking for as far as ribbon/woofer and crossover condition. I am thinking of using a M-4.0t amp if I do get them, anyone out there use that setup?
HRDROKN
Post Sat Jun 11, 2011 4:15 pm
Re: AL-lll+ audition
67ih4x4x4 wrote:I'm going to audition a pair of AL-lll+ tomorrow . Does anyone have any sugestions on anything I should be looking for as far as ribbon/woofer and crossover condition. I am thinking of using a M-4.0t amp if I do get them, anyone out there use that setup?
No suggestions ... just wish I was going along with!
=P~
HRDROKN
Post Sat Jun 11, 2011 4:30 pm
Play them at high levels. Listen for ribbon buzz or woofer flap. Listen all the way up the ribbon and then lay flat and listen to the woofer. They are great speakers if properly working.
Post Sat Jun 11, 2011 4:43 pm
kingman wrote:Play them at high levels. Listen for ribbon buzz or woofer flap. Listen all the way up the ribbon and then lay flat and listen to the woofer. They are great speakers if properly working.
Take a CD with a Girls/womens voice and Piano that should help expose any possible buzzing!
Post Sat Jun 11, 2011 4:52 pm
Where are you auditioning them?
Female voice & dynamic piano are excellent "revealers". Dianna Krall, Norah Jones are double threats!
Post Sat Jun 11, 2011 5:55 pm
listen to the woofers, if they rattle or make noise, subtract at least 150.00 from the price....
got a test tract cd? test tones will also bring out the flaws, especially the woofers
that amp will drive them okay.....
but then you will want more....... :lol: :lol: :lol:
67ih4x4x4
Post Sat Jun 11, 2011 6:44 pm
Good info ! I plan to take a little fourplay and the Linus and Lucy track havn't figured out the vocals yet. Sound like their aren't alot of visual things to look for.
Post Sat Jun 11, 2011 7:15 pm
look at the ribbons, bring a flashlight, look for damage,.....
ie:tears, small holes from kid fingers, or pencils.... ](*,)
corrosion spots, real loose areas of ribbon, not a total deal breaker, if they sound good and the price is right....etc
remember these things are close to 20yrs old.
these will have a horizontal lines in the ribbon, or they may have a wrinkled looked to them, the full length of the foil, this is normal.
my al3's range from just a light line to a real deep peak to peak look
good luck
ps: if they dont sound right, buzz, creek,ribbon slap....
if the price is more than 350/400$ walk away, these pop up often enough to get a good set, I've walked from 2 sets....
Post Sat Jun 11, 2011 9:01 pm
That will be a lot of work for your M-4.0. I ran my AL-IIIs with a TFM-45 for a short time (similiar amp) and it struggled.
67ih4x4x4
Post Sun Jun 12, 2011 9:14 am
Well if I get them sounds like an excuse to get another carver amp !!!!!!!!!
Post Sun Jun 12, 2011 1:11 pm
if you get them, a sunfire 300x2 will make them sing. as well as a set of new high grade/high dollar capacitors for the xovers, wow i say.
Post Sun Jun 12, 2011 10:32 pm
M4.0 will running them great. 1st try it. I believe you will be very happy with the two together.
Post Mon Jun 13, 2011 7:37 am
SO....how'd it go?
67ih4x4x4
Post Tue Jun 14, 2011 11:24 pm
I did get them ! They look very good ,very well cared for no holes,or wrinkles in the ribbons and the woofer surounds had been treated years ago to keep them pliable. I just had enough time to get them home and throw speaker wire to them for a quick fix! They didn't sound as good in my room but I didn't have time to even start working on placement and adjusting the crossovers. I will have to say that they do like power, I noticed that leds on my m-4.0t move a lot more than on the other speakers they where driving. I did happen to buy a 7t last week, I might try to run one with the 7t and one with the 4.0 in mono just to see how they compare to each other. I am out of town until thurdsay I hope to do a little playing then.
Post Tue Jun 14, 2011 11:41 pm
From what I understand, placement is "everything" on these speakers. Congratulations!
