It is currently Wed Jun 19, 2013 10:01 am
AL-lll+ audition
Post Thu Jun 23, 2011 10:51 pm
Re: AL-lll+ audition
A TFM-42/45 would be perfect for your woofers, easier to find and the same power rating. I've got an original Sunfire Cinema Grand 200x5 running my AL-IIIs bi-amped and it sounds great and goes plenty loud. There was just one on eBay (purple) for $650 shipped.
Post Fri Jun 24, 2011 4:39 am
^^^^yes^^^^^
Biamping is the way to go with those speakers. Horizontally if different amps, vertically if the same amp.
67ih4x4x4
Post Fri Jun 24, 2011 11:36 am
Let me see if I understand you Mr Rabbit . Use one amp to run the highs and lows on the same speaker if both amps are the same, and use one amp to run highs on both speakers and the other to run the lows on both speakers if the amps are different.
Post Fri Jun 24, 2011 11:43 am
Correct. I like the first choice better because usually the demands of one half of the speaker are greater than the other at any moment in time, and that balances the use of the power supply in that amp. Whereas, the demands on one part of the speakers in both channels (stereo) are similar.
67ih4x4x4
Post Sun Jun 26, 2011 9:04 pm
I switched back to just the m-4.0t running both Al-lll's. I like the sound better , not overly impressed with the 7t though it does have plenty of power. Maybe it needs recapped or tuned up.
Post Sun Jun 26, 2011 10:55 pm
67ih4x4x4 wrote:I switched back to just the m-4.0t running both Al-lll's. I like the sound better , not overly impressed with the 7t though it does have plenty of power. Maybe it needs recapped or tuned up.
That would be my thought - Time to have them up-dated. The 7t should sound impressive or at least equal to the 4.0t
