Wed Nov 19, 2008 1:15 pm by elgrau
Guess I'd have to agree with RR and F1. Don't make the mistake(s) I made when building my EPI 1000's: I tried (at first) to "save money" on the woofers and found that anything short of pure originals can only drive you nuts (even if you think the "bargain" route drivers (or x-over caps!) sound ok, it drives you nuts wondering whether or not the sound could/should be better. And 99% of the time it will). EVERYTHING effects speaker sound; the original designer(s) threaded a needle to get the "perfect" sound that they were designing for; any deviations from that will most likely be negative. For what I wasted on drivers that did not work out I almost could have bought all 100% new drivers from Huw at humanspeakers.com (I did buy two from him and used them in the front faces of the speakers)...but I settled for (the remaining six) used (exact replacement) EPI drivers from ePray (4 ohm, not 8 ohm!)..some I had to refoam, some were allready refoamed. Re-foaming is no gimme either, but the kits I buy have very detailed instructions and checks to make sure you do it right...unless u r a clutz, in which case, don't try it!
That said, your only other option might be to ship your drivers to the link I posted earlier and have them professionally refurb/refoam your drivers, but after the one extra shipping charge and what they charge for this refurb, I doubt you'd save much over new drivers. Might try buying new ones a few at a time so as to budget this expense?
Ed
