It is currently Sat May 25, 2013 6:45 am
aluminum for carver
ribbonspeaker
Post Mon Mar 19, 2012 5:35 pm
aluminum for carver
I am looking for the aluminum to rebuit my 30 inch Carver . Does anybody know where I can get a hold of these material.
thank you
Post Mon Mar 19, 2012 8:03 pm
Re: aluminum for carver
The kapton material is available from 3M I believe, but they only sell in GIANT rolls (like 3000 feet or so). James (Toy Maker) may be able to give you more info.
Post Tue Mar 20, 2012 1:35 am
hello ribbonspeaker, welcome aboard. good luck for sure as the mylar replacement for the panels. i just had a 30" done by alex and james this past week. what james uses is manufactured and sold in a large quantity that is in the thousands when the sauters order a new batch. you have taken on a real undertaking i am sure to get it done in a small quantity. please keep us informed on how it comes out. cheers
ribbonspeaker
Post Tue Mar 20, 2012 3:31 pm
Instead using Kapton, I am using Mylar 6 micron from Ebay. I also running 2 aluminum strip instead of one as the original . It very a fun project. I am using the aluminum foil from Costco food court which is about 6 micron. I was able to cut 3mm strip. However it is only 13 inch long so I glued them together by the automotive rear window defroster . I will post the pictures before and after sometimes next week
Post Tue Mar 20, 2012 3:43 pm
Welcome
Post Tue Mar 20, 2012 6:49 pm
I'm going to call this for what it is, a complete cluster fuck.
Post Tue Mar 20, 2012 7:02 pm
F1nut wrote:I'm going to call this for what it is, a complete cluster fuck.
Cut to the chase!!!!!!! :lol: :lol: :lol:
Post Tue Mar 20, 2012 7:17 pm
Post Tue Mar 20, 2012 7:51 pm
What is a capcitors?
BTW, neither link works.
Post Tue Mar 20, 2012 8:27 pm
You hold back to much F1. You need to open up and speak your mind! :lol: :lol: :lol:
Post Tue Mar 20, 2012 9:04 pm
fixed the links, crappy comp at work, it's like 900yrs old.... ](*,) ](*,)
and no spell check.... :-" :-"
ribbonspeaker
Post Fri Apr 06, 2012 12:35 pm
Problem solved.
I got the aluminum foil 11 micron thickness from the local japanese store. it turns out Japanese use the thinner aluminum
it is very cheap 1.5$ for 22mx25cm.
Our carver aluminum ribbon is 13micron .
I was able to cut into 3mm with 2 meter long by folding the sheet 2m (coated with veg oil) .
then I folded in to 1 piece : 1 side is about 1.1 the other is 90 cm and so on to the final 25 cm .
Then I used the paper cut and slammed it down to the size I want.
note: oil coating between the aluminum to make it easy to seperate after cutting and fold uneven is also help .
Post Fri Apr 06, 2012 1:26 pm
I'd really like to see some pics of this....
ribbonspeaker
Post Fri Apr 06, 2012 5:32 pm
How do I post them ?
Post Fri Apr 06, 2012 7:20 pm
i use photobucket.com for such things.
