It is currently Thu May 23, 2013 4:29 am
aluminum for carver
Post Fri Apr 06, 2012 8:55 pm
Re: aluminum for carver
I use photobucket, too.
You upload the pics then use the link in your post.
ribbonspeaker
Post Sun Apr 15, 2012 6:56 pm
Post Sun Apr 15, 2012 7:01 pm
whats your photobucket name?
Post Sun Apr 15, 2012 7:03 pm
I just wrapped 2 steaks in that????
ribbonspeaker
Post Sun Apr 15, 2012 7:05 pm
ribbonspeaker
Post Sun Apr 15, 2012 7:07 pm
did you guys see it?
ribbonspeaker
Post Sun Apr 15, 2012 7:11 pm
http://www.coverite.com/covering/covq0240.html
here is the link for the microlite
ribbonspeaker
Post Sun Apr 15, 2012 7:56 pm
AlexSauter
Site Admin
Post Sun Apr 15, 2012 10:17 pm
BEFORE YOU BLOW UP YOUR AMP, STOP!!!!!!
The impedance for a 30" ribbon is 1.8 ohms, if you run that speaker with any amp, you have a very good chance of damaging it. Even if you put that one completely back together, it will continue to read .4 ohms, the magnetic field does not change the impedance of the speaker, just the thickness of the aluminum trace. The aluminum you are using, just by dividing 1.8 by .4, is 4.5 times thicker than what you need....
The cost to send it to us is $235 (plus shipping) and it will come back to you as new as it had come from the factory.
As far as the where we get out supply, the company that we get the Kapton, the same as the OEM material, only sells in $5000 usd bulk amounts.
RIP BillD
(Stereo System)
Carver Pro PT-1800
Sunfire Prototype TGA-2375
Carver TX-2 Tuner (not used)
ribbonspeaker
Post Mon Apr 16, 2012 12:08 am
Thank for the warning . I am not there yet.
Right now I have problem with removing the glue from the microlite membrane.
Then I need to glue all the magnets back together.
Then I will check for the ohm. I will add R to it to bring it up to 4 ohm .
I didn't invent it . I just reverse- engineer .
I have to admit . The Carver ribbon is not only a wonderful speaker but it also is a piece of Art . The ribbon speaker is worthless without the aluminum etch membrane .
Post Mon Apr 16, 2012 11:57 am
"You hold back to much F1. You need to open up and speak your mind!"
too much...
(keeping with the general theme of this thread/cluster fuck! At least get the grammar/spelling right :lol: ). I agree with F1/Toymaker: the odds of this "project" leading to anything but a cluster fuck/blown amp/waste of time and money are on the low side of between slim and none.... :lol:
But have fun! :lol:
ribbonspeaker
Post Tue Apr 17, 2012 2:59 am
I know there is a problem . Wash your mouth with soap . [-X
ribbonspeaker
Post Tue Apr 17, 2012 3:06 am
Alex. Please let me try it out.
I have 3 x 30 inch ribbon speakers and 1x 60 inch ribbon speaker . They are all broken . That is why I can effort to mess around with it . I might have to send you the 60 inch for rebuid. However, the magnets are out of place . It is a mess.
Thank for the warning.
