It is currently Wed Jun 19, 2013 9:13 pm
Can Plat x-overs be modified to bi-amp?
skip
aka (Sasquach)
Post Thu Apr 26, 2012 4:35 pm
Well, I'm finally getting close to rebuilding my x-overs. I've got a pile of sonicaps waiting to go in and plan on getting some Mills resistors to replace the old sand resistors. I'd also like to replace the coils if someone knows a source. When I do, I'd also like to replace the terminals and set it up for bi-amping. Is this possible? I'll probably have to build a new box to mount on the base as the Sonicaps are friggin huge and I doubt they will fit inside the back cover.
Sasquatch
Post Thu Apr 26, 2012 6:07 pm
Re: Can Plat x-overs be modified to bi-amp?
yes, easy like.
Post Thu Apr 26, 2012 9:17 pm
Skip, you're going to have a problem using Mills resistors as they max out at 12 watts and most of the stock resistors are 25 watt, IIRC. There is one type of Mills resistor with a heatsink that is rated at 50 watts, but it's not really audio grade.
skip
aka (Sasquach)
Post Fri Apr 27, 2012 7:53 am
What type of resistors should I look for? Will the stock ones in the x-over work fine or can improvement be had by swapping them out? How about the induction coils? I know Rolland offers new coils in his rebuilds. Any idea where to find new ones?
Sasquatch
