It is currently Mon May 20, 2013 8:32 am
New Carver Amazings!
Post Sun Jan 20, 2008 8:34 pm
I'll put in my two cents on this one! I run my pair with a 600x2 and never had a problem with anything I was playing ! Eddie!
Post Sun Jan 20, 2008 8:58 pm
I run mine with a Lightstar 2.0 and they sound great.
Post Sun Jan 20, 2008 8:59 pm
I don't know about the Originals, but I can attest to the fact that a (pair) of TFM-45's each bridged mono was just about enough juice for them. Make sure you upgrade the breaker though, you'll trip it if not :)
wildhair
Post Sun Jan 20, 2008 11:34 pm
Just because your paranoid doesn't mean they aren't watching you.
tfm35
Post Sat Apr 17, 2010 2:10 pm
Re: New Carver Amazings!
All these high numbers of watts sure are impressive fellow members.
But we do not listen to numbers, or do we?
I purchased a Jeff Rowland, Model-1 in the early 90's about the same time with my Silver Amazings.
This power amp only has 60-watts per channel.
And you don't need more than 25watts from this amp to bottom out the 6 woofers with a good dynamic recording CD.
it uses two 40,000uf condenser.
tfm35
Post Sun Apr 18, 2010 7:17 pm
Just saw this silver 7 amp offer on eBay...#270564395295.
http://cgi.ebay.com/Carver-Silver-7t-mo ... 3efee5091f
