Close look at my ribbons
brentslone
Post by brentslone » Fri May 28, 2004 1:52 pm
I've attached a photo of my Mark IV Platinum ribbon. Two questions:
There are a couple places where the aluminum foil has delaminated from the kapton (as seen in photo). Is this level of delamination a problem?
Also, if you look closely, you'll notice that the aluminum traces are not aligned with the opening between the magnet structures. The left trace is a few millimeters away from the magnet and the right trace is slightly under the magnet. Is this common or an issue?
Thanks,
Brent
Closeup of Mark IV ribbon (right speaker)
Post by F1nut » Fri May 28, 2004 9:28 pm
Your pic is too big, looks bad and I can't tell what's what. How about another smaller pic.
brentslone
Post by brentslone » Sat May 29, 2004 6:22 pm
F1nut,
Is this a better view?
closeup of top of right ribbon.
Post by F1nut » Sat May 29, 2004 9:13 pm
Yes, much better....thanks.
On looks alone I'd say you've got some issues, but if they aren't buzzing don't worry about it.
Post by DaveS » Sun May 30, 2004 2:17 pm
When I buy Kapton it sometimes comes with some little wrinkles in it. I`ve had some of the wrinkles on my own set of Platnums for years and have not had any trouble as of yet. If you were to have a problem that is where I would expect it to be but until than run`um like you own`um.
tah800
Post by tah800 » Mon Jun 07, 2004 9:25 am
Are these original platinum ribbons or did you have them redone???Art
Post by DaveS » Mon Jun 07, 2004 2:44 pm
They look original to me.
brentslone
Post by brentslone » Thu Jun 10, 2004 1:12 pm
I believe they are original, like DaveS said. I was told by the previous owner that they had not be repaired.
Return to “Carver Speakers”
