It is currently Thu May 23, 2013 4:23 pm
which amazing platinum edition do i have
• Page 1 of 1
My platinums i just got second hand are oak, have the 60 inch ribbon and 4 woofers, but no serial, no other markings. any clues? on the back i have the ability to biwire and two fuses. nothing else other than that? oh and my grills have a carver logo on the bottom corner only.
Hey ID,
Congrats, you have a pair of Platinum's.
Specs are as follows:
Freq. response 23Hz to 40kHz -3db from reference
Impedance 8 ohms
Sensitivity 89dB
Power Handling 60 wpc to 750wpc
Max. SPL 121dB
Weight 110 lbs. each
What do have for power???
Impedance 8 ohms
Sensitivity 89dB
Max. SPL 121dB
howdy f1 long time no see/hear
i traded my polks in for the carver amazings and a pair of klipsch rf7s
i dont have power yet, i was looking at the carver 1.0, 1.5, or even a pro model amp. is using a pro model amp better/worse than a hifi amp?
also which version of the platinum do i have? is there a way to tell? i know the first edition used two 30'" ribbions, but what about the 2nd and 3rd and 4th editions?
That's what you have, the Platinum edition. The first ones were the Carver Amazing's, sometimes called the "Original." Then the Platinum's and then the Platinum Mk IV. There was another one called the Silver edition, but it was a smaller version with a 48" ribbon and only 3 woofers.
As for a amp, either home or pro will do, just make sure you get one with as much power, current and damping as possible.
BTW, you can buy a owners/service manual from http://www.vintageaudiomanuals.com
The Mk IV's have tone/eq controls on the back and therefore a slightly difference crossover.
• Page 1 of 1
