It is currently Thu Jun 20, 2013 3:49 am
need a visual model for CAL's
• Page 2 of 5 • 1, 2, 3, 4, 5
an-eagalach wrote:I just called my local lumber company. The salesperson said they carry "Baltic Birch" which is a plywood. It's a 1/2 inch, 5' x 5' sheet for $42.43. She couldn't tell me anything else about it though. Before I run out there, does this sound right? It's only a half inch thick though.
Yup! Same stuff, but the inch and inch and a half thick stuff is usually special order unless your lumberyard specializes in hardwoods, veneers and other woodworker's woods instead of general construction materials. I am fortunate to have 3 such lumberyards in close proximity to me (the advantage of living in a large city with lots of craftsmen). If you can only get the half inch stuff, you can easily glue and press 2 together to get 1 inch thick stock. Can anyone measure the overall thickness of the Amazing's panels?
(Pair of Silver 9t's)
OBI56 wrote:maddmaxxx wrote:-1"
Thanks maxxx, now can I bother you for the other measurements please? Hight width at both the top and bottom? I'd like to see if I can find a way to get the correct size here to make proper 1 inch thick panels.
OBI-san...are you up to what im thinking your up to
if in your hunt you can rustle up an extra 30" ribbon for your friend the assassin id be very much in your debt.
Thanks again maxxx. I'm not sure what you think I'm up to, but I'm just trying to find a way to help out an-eagalach with getting his panels the correct size by knowing what size lumber he will need. Can't swear to it, but I think he needs the size for Plats or Originals.
Now, what is AA77 up to that I should know about???
Marc .....
Marc .....
Trapazoid
Hi Obi, Maxx is right on (as usual) in the measurements of the silvers, He being the "silver king".
I thought I should add that the inside edge is straight. That is the side that houses the ribbon is 90' top & bottom. The outer edge (woofers) slants inward bottom to top. Just in case.
Frank.
Frank.
audioassassin77 wrote:OBI56 wrote:maddmaxxx wrote:-1"
OBI-san...are you up to what im thinking your up to.
late reply again
Mr.OBI-san. judging from your posts in this thread id almost become convinced that you were also looking at "rolling yer own" AMAZINGS(or a smaller version of same).
i could be mistaken of course(not the first time).
LOL@AA77!!! Interesting idea, but why would I want to roll my own when I have still to hear what they sound like and if I would even like them? + I'd be looking at building AL-III clones before Silvers or Plats due to the size issue.
Hmmmm, just got a weird idea .... Wonder if I could source a pair of 30" ribbons and build some mini AL-IIIs (AL-1.875s?) no crossovers but fully bi-amped ...............
OBI56 wrote:LOL@AA77!!! Interesting idea, but why would I want to roll my own when I have still to hear what they sound like and if I would even like them? + I'd be looking at building AL-III clones before Silvers or Plats due to the size issue.
funny.
id thought you were thinking along the lines of scaled down amazings.
same trapazoid shape 1/2 size would be mighty interesting.
active cross, 2 12" drivers per with a single 30" ribbon.
if you were to use the aforementioned butchers block id bet you could come up with some nice small drafts.
Actually, with 30" ribbons, they'd be AL-1.6s, because AL-3s have 48" ribbons. The real problem is getting 6¼" woofers. Still be cool, though. They'd be about 45" high. The woofer box would be about 14 3/8" high.
BillD wrote:Actually, with 30" ribbons, they'd be AL-1.6s, because AL-3s have 48" ribbons. The real problem is getting 6¼" woofers. Still be cool, though. They'd be about 45" high. The woofer box would be about 14 3/8" high.
Correct as usual BillD. I remember thinking they would be 1.6's but when I ran the figures through my calculator I came up with 1.875 for some reason (probably something having to do with an extra inch somewhere). I knew it sounded wrong, but hey, I'd been out shoveling all evening and was warming up with a hot Irish coffee, so ......
I'd still want to use 10' subs for an AL-III type speaker IF I were to build one, but AA77's idea of Mini Plats with 2 woofers is intriguing. The acoustics alone of a 2 woofer trapezoidal setup would be devilishly complicated to figure out.
