Mon Dec 01, 2008 5:24 pm by BillD
Well, you have a pair of woofers, so 150Hz isn't a bad number. I have some 12" AR3a woofers that handle anything from 575Hz down when they are coupled with the midrange and tweeter. You really only need to go down to 80Hz if you want ONE woofer (i.e., a subwoofer). They say that that is the frequency where sound becomes omnidirectional.
Don't understand the issue you're having unless it just isn't enough power. I do like Rabbit does. 800 watts on each ribbon and on each woofer.
