Subwoofer integration with Amazings
I do not have a dedicated subwoofer output on my preamp (so no setting for small/large speakers either), after researching many different subs I see that some have pass threw crossovers that can actively send only the desired frequencies to the sub and at the same time only the above cut off to the mains, as other subs (most common) only filter the sub input frequency and you still have all the frequencies to the mains.
First off what frequency should the sub crossover be, I was thinking somewhere around 50hz as the Amazings do go pretty low?
Second, should I use the filter/crossover to cut out the frequencies the sub will produce to let the Amazings breath more (I would think so), the sub would do the 15hz to 50hz, and the Amazings would do the 50hz and up, or simply let the Amazings overlap the sub frequencies down to there own limit?
I forgot to add that I run all of my speakers in full range (large setting) with SMS-1 controlling the subs (for HT).
