Re: Need help for carver amazing
It is currently Sun May 19, 2013 12:52 am
The other guys have posted on the amps but I think I would go with a Sunfire. Good bass output and they don't run out of gas as the speakers get louder.(pair of) SILVER-7 TUBE AMPs
kingman wrote:If you don't mind the fan noise, the PM 1.5 bi-amped will do the trick. Also easiest on the pocket!
TNRabbit wrote:kingman wrote:If you don't mind the fan noise, the PM 1.5 bi-amped will do the trick. Also easiest on the pocket!
I'm pretty sure bi-amping is not an option on the Upgraded Original speakers....
H20doctor wrote:TNRabbit wrote:kingman wrote:If you don't mind the fan noise, the PM 1.5 bi-amped will do the trick. Also easiest on the pocket!
what do you mean ?
