Which taps?
Gordon
It is currently Thu May 23, 2013 4:57 am
F1 is correct in saying they are rated nominal 8 ohm, the 6.5 figure comes from the total of the woofer and ribbon resistance. The woofers are 4 ohm and the ribbons 2.5-3 ohm.skip wrote:Or better yet, power them with a pair of silver 9t blocks and don't worry about ohms ever again.F1 is correct in saying they are rated nominal 8 ohm, the 6.5 figure comes from the total of the woofer and ribbon resistance. The woofers are 4 ohm and the ribbons 2.5-3 ohm.
